Soccer Ball / Football
Introduction: Soccer Ball / Football
This instructable will be a detailed step-by-step plan that teaches you how to create your own football.
Step 1: Materials
In order to create the football you will need the tools and materials shown above.
The list is as follows:
- 25 garbage plastic bags
- 1 ball of string
- 1 old piece of cloth that is at least 30 by 30 centimeters
- One roll of painter's tape
- Spray paint in any preferable colour (Optional)
- Scissor
- Black Marker (Optional)
Step 2: Making the Core of the Football
You will be making the core of the football first.
Begin with unrolling a plastic bag and unfolding it. Unfold 25 more plastic bags. In total you will have 26 unfolded plastic bags. Take one of the 26 and stuff the other 25 bags into it as shown in the picture above.
Step 3: Making the Core of the Football
Close the plastic bag full of plastic bags and twist the end to make the bag as tight as possible. Watch out to maybe poke some holes into the plastic bag in order to let air escape. Try to press the ball as tight as possible. Tie a piece of string around the twisted part and cut it off.
Step 4: Securing the Core With String
Tie a loop around the ball. After having done so, use the string attached to the loop, to wrap the plastic bags as tight as possible. Try to give the football a better round shape, through wrapping the plastic bag in strategic areas. After the ball has a fairly round shape, you can tie the end of the string securely to another piece of string wrapped around the bag.
Step 5: Making the First Layer
Now make use of the first piece of cloth.
Place the ball in the middle of the cloth. Wrap one corner over the ball and tuck it below the ball. Do the same with the next corner. The last corner will have to be laid over the first two corners. After having done so, secure the cloth in place with some painter's tape.
Step 6: Making the Second Layer
The layer of cloth, was there to add size, weight, and something for the next layer to hold on.
The next layer will consist of pure painters tape. This layer is there for you to mold the shape of the ball and to make it as round as possible. Place srtaps of tape around the ball in strategic areas. When you are satisfied with the shape, cover the rest of the areas of cloth with some more tape.
This layer will protect your ball and make it a bit more sturdy.
Step 7: Adding Design Elements
This stage is purely the design of the football.
Spraypaint your football in the colour you want or add cool lines.
The video will show you how I did it.
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    Do you poke holes in it? I'm confused because you said to watch out about it on step 3.
    I guess i wouldn't need a football like this but its a really cool idea!!
    This changes whether you play rough or not and outside or inside. If I were to guess, the football should hold you for about 5 to 10 games of 30 minute lengths.
    However, in case the football breaks, it is easy to repair it with some more tape.
    Great idea! How durable is it?
