3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Footrest helps kids sit comfortably at the table
Step 4Add the Crossbar Mounts
Now it's time to add the mounting points for the crossbar. This is the horizontal piece of pipe on which your child will actually rest their feet.
  • Drill a hole through each of the 3/4" 'T' couplers, about 1/2" from one end, just big enough for the thumb screws. (see picture for hole placement)
  • Remove the thumb screws from the 'T' couplers, and remove one collar from each riser.
  • Slide one 'T' coupler onto each riser with the hole you just drilled at the top and screw the collars back on, making sure the upright rests flat on your work surface.
  • One at a time, hold each 'T' coupler at the top of its riser and use the holes you already drilled as a guide for drilling through the riser.
  • Note that the height of the cross bar is adjustable by drilling additional holes closer to the bottom collars, but don't put the holes too close together! I recommend waiting to drill additional holes until you need them.
  • Insert the thumb screws and screw on the wing nuts to hold the 'T' couplers in place.
The result should look like the second picture below.
Now you are ready to assemble the cross bar on which your child will rest his (or her) feet.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:wramey
