For the Budding Geologist: How to take the dip measurement of a slope
 by jonas078
Tired of looking at sloped rock beds and not knowing the angle at which they are tilted? Allow me to help you put your curiosity to rest.
Materials You Will Need:
1) Compass with clinometer
2) Water
3) Sloped Surface
Note: Place your cursor arrow over the yellow boxes in most pictures for further explanations.
Step 1: Align Your Compass
Turn the compass dial so the East and West symbols are aligned with compass markers. Make sure the N (North) symbol is aligned with the 0 degree marker on the clinometer.
CAUTION: Your compass markers and other compass features may be different from mine. However, they should be similar enough that these directions will work for any compass.
Step 3: Place Compass Parallel to Water Flow
As you align your compass parallel to the water flow, make sure that the North symbol is pointing down, this ensures your clinometer is also placed correctly.
TROUBLESHOOTING: If your N symbol and clinometer are not in the same quadrant of the compass, you have your E and W symbols backwards. Just twist the compass dial 180 degrees to switch them.
Step 5: Find the Direction the Slope is Dipping
To find the direction your slope is dipping:
1) Align your North symbol to true North.
2) Point your compass in the direction of your slope
3) Read the symbol on your compass to determine the direction
Record the direction as either N, S, E, W, NE, NW, SE, SW. In this case our slope is dipping in a South-East direction so we will choose SE.
NOTE: If, for example, the direction is only slightly off of East, you need to record the direction as East. The slope direction needs to be close to half-way between two directions to justify a SE, SW, NE, or NW.
Step 6: Record Your Measurement
The measurement of dip is always written with the number in degrees and then the direction of dip. In our case we would record:
22SE
CONGRATULATIONS! You're on your way to uncovering the secrets of the earth!
billbillt says: Feb 29, 2012. 9:38 AM
You made this esay to learn...Thanks!...
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
