There are a lot of pictures, and I hope they help explain what I am doing. Sorry, no action shots. I don't have anyone to hold the camera : )
Let me know what could be clearer, and what I should take out. Doing it is so much easier than trying to explain how to do it for me.
Remove these ads by
Signing UpStep 1Where to begin...
If you start with a 'new' coil spring from a car, it will need to be cut down. I find it easiest to throw the coil spring into a bonfire, let it get hot, then cool off (anneal, or soften, or remove the temper) then cut it with an angle grinder
http://en.wikipedia.org/wiki/Angle_grinder
or high tension hacksaw (worth the extra few dollars).
http://www.stanleytools.com/catalog_images/mid_res/15-113_mid_res.jpg
http://www.stanleytools.com/default.asp?CATEGORY=HACKSAWS&TYPE=PRODUCT&PARTNUMBER=15-113&SDesc=12%26%2334%3B+High+Tension+Hacksaw
If you skip the annealing, you use up a lot more blades and elbow grease whether you use the angle grinder or hacksaw. If you use a flat spring from a car, you don't have to anneal, but I find that kind of spring a bit awkward to hang on to.
NOTE: protect your eyes! The angle grinder throws off more sparks than a firework and they get into the most painful places.
NOTE: cut metal is HOT! An angle grinder is faster, but all those sparks are burning steel. Whatever you are cutting will get hot, even if using a slow hacksaw.
NOTE: cut metal is SHARP! Even a flat edge has burrs that will grab your skin and tear it open.
I did part of this last fall, so I don't have any pics of the annealing or cutting : P But here's the end result.
I'll be using the big round piece.
I'm with you, I can't seem to get any good ones yet, I use a large pair of channel locks and some tongs somone else gave me.
2 layers folded becomes 4, 8, 16, 32, 64, 128, 256, 512, 1024, 2048, 4096, 8192 layers after folding 12 times. It's 12! (factorial) not 12x12 (squared).
The early iron-smiths had to average out the carbon content of what they had, and so had to mix the metal by folding it. Bessimer fixed that.
that we work with these, things all day. Its nice to see them put use rather just sit there at a scrap yard or in the wear house, and with customers always buying new leaf springs --- obviously they have
old leaf springs; so we decided to write about a trend we've spotted on your site and show our customers what some are doing with their old leaf spring metal. So we wrote an article about it which you
can find here. Hope you enjoy!
I think someone on Anvilfire said that an anvil should be at least 25 times heavier than the hammer you are using, and I've found that lighter anvils bounce around : ) For knives and swords, mostly you need a flat surface-use an angle grinder if you have to-and occasionally a chunk of something round or a rounded edge on your anvil to do some of the transition areas.
A torch can work, but you loose a LOT of heat without something to reflect it back into your work (like the walls of a gas forge). Try making a bean can forge or even a pile of clay brick (NOT cement pavers) or fire brick to hold the heat around the metal.
If you use the sledge hammer, make sure the surface that's up is flat-ish, or your metal will have weird marks you'll have a hard time getting rid of : )
Thanks
