Step 10Grind or file to shape
I started by grinding the bump off the back (coarse grit wheel) and evening out the cutting edge (fine grit wheel). If your grinder has a grinding wheel and a wire brush, then just do what you can. After the rough shaping, I sharpened the blade. Keep dipping the blade in a bucket of water, it will help keep the metal cool. when you can see that the water has evaporated, dip it again.
comment
Add Comment
Add Comment
