Step 11Finishing up, or, what's left to do
I should have thought more about the balance of the blade across the handle, hammer out the dip in the back and maybe a bit of a false edge. The rat-tail tang is easier to put a handle on, you drill a hole in the handle a little smaller than the tang, heat the tang up and burn the hole the right size. Any extra tang that sticks out can be handled in a number of ways-bent over like a nail, cut the extra off or put a nut on it to keep the handle tight. A loop handle could have been done, heating the middle of the tang, then bending the end up like a U until the tip touches the base of the blade.
Total time, little more than an hour, not counting the bonfire : ) Probably another hour to grind off the rest of the scale (or soak it in vinegar for a day or so) and make a handle.
I think someone on Anvilfire said that an anvil should be at least 25 times heavier than the hammer you are using, and I've found that lighter anvils bounce around : ) For knives and swords, mostly you need a flat surface-use an angle grinder if you have to-and occasionally a chunk of something round or a rounded edge on your anvil to do some of the transition areas.
A torch can work, but you loose a LOT of heat without something to reflect it back into your work (like the walls of a gas forge). Try making a bean can forge or even a pile of clay brick (NOT cement pavers) or fire brick to hold the heat around the metal.
If you use the sledge hammer, make sure the surface that's up is flat-ish, or your metal will have weird marks you'll have a hard time getting rid of : )
Thanks
