Introduction: Fork and Gemstone Bracelet
Picture of Fork and Gemstone Bracelet
Today we'll teach how to make a bracelet with a common fork and a semi-precious stone.
Step 1: Supplies
Picture of Supplies
You will need:
a fork: the thinner and softer to bend, the better
a round-nose pliers
a needle nose pliers
Step 2: Straightening the Fork
Picture of Straightening the Fork
Use the needle nose pliers to straigten the fork.
If you have a hammer and anvil at home, you can straigten the fork with them instead of the pliers.
Step 3: Preparing to Set the Stone
Picture of Preparing to Set the Stone
Bend the external tines of the fork up, in square angle. Then, bend the internal ones laterally, keeping an angle of about 30 degrees between them.
Step 4: Setting the Stone - Part I
Picture of Setting the Stone - Part I
Now we'll start to set the stone. First, choose the position of the gemstone: choose the position in which it fits better the piece we already made, then set it aside while we work with the first tine.
Use the rounded nose pliers to make the first turn of the spiral, and the needle nose pliers to make the other turns. Don't curl up the whole tine, leaving plain a piece. The size of this piece depends on the height of the gemstone.
Now, bend the tine with the spiral upward of the stone. Use the images as reference. Do the same with the other external tine.
Be sure that the gemstone is firmly seated between the tines. Next step we'll finish the setting of the gemstone.
Step 5: Setting the Stone - Part II
Picture of Setting the Stone - Part II
Do the same of the previous step with the two internal tines: twist the ends of the tines, then bend them upward of the stone, this time without twisting again. Remember not to twist the whole tine, leaving some space flat**. The size of this space will be approximately the same as the height of the gemstone at that point.
Step 6: Bending the Handle of the Fork
Picture of Bending the Handle of the Fork
Use the needle nose pliers to bend the handle of the fork, so it gets the shape of a wrist. See the images to know where to bend. Depending on the hardness of yout fork, you may have to use some strenght, or support on some surface, like we did.
Step 7: The End!
Picture of The End!
That's it! Check the other bracelets we have made with the same technique, and a video showing how to put it on!
flembag (author)2014-07-29
cool idea and a faster way to flatten it would be to just put it in a vise
scooter76 made it! (author)2014-01-31
Very cool idea and fun to make, my only comment would be to make sure you pick a fork with long tines. I started on a smaller fork not think, and they were to short. Very fun and easy to make. Thanks for posting.
gmacv (author)2014-01-04
Very well-done tutorial. Thank you. I have tried, unsuccessfully, to bend forks for jewelry. I guess I need to find more flexible forks and try again with your guidance.
CrystalB01 (author)2014-01-03
I'll have to make this now hahaha great instructable
interestedturtle (author)2014-01-03
I made this for my sister and she loved it.
dimtick (author)2014-01-02
very nice design!!!!!
I even think this would look great without the stone if you do some curly pattern with the fork tines.
Nice Job!
andrea biffi (author)2014-01-02
that's beautiful and very unusual...
wildviolets (author)2014-01-01
wow!!! I love this! This will be my next venture in DIY-ing. I have collected a few old and pretty forks and they will make beautiful braclets.....thanks for sharing.
quickie817 (author)2014-01-01
Very creative and out of the box thinking!! I love it!
faiza007 (author)2014-01-01
this is such a gr8 idea..!! i love it.. :)
About This Instructable
9,486views
434favorites
License:
More by Trupe Por um Fio:Drawing a mandala in 5 minutesFork and Gemstone BraceletCopper Ring With Brazilian Seed
Add instructable to:
