It turns out this has someting to do with the RAID setting in the BIOS (F2 at startup).
GO TO:
- F2 at startup
- Drives
- SATA Operation
in this option it is set at RAID: On
the only other option is RAID: Autodetect / ATA
set it to RAID: Autodetect / ATA and save and exit now restart with the XP CD in the drive and boot from CD.
everything should run smooth and normal now. it worked first shot for me and I haven't had a problem. the Dimension E520 is a decent machine with XP on it. does everything it needs to do for my GF who is an occasional Comp user. it was a paper weight with Vista on it
hope this helps crappy dell users out there.
(This worked for DELL computers (PC's) I have encountered. I have no idea if this will work on any other machine)
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
Correction: "Format Dell Computers - Upgrade to XP from Vista"
http://www.instructables.com/id/Upgrade-your-new-laptop-from-Vista-to-XP/
And weirdly a patch to make Xp look like vista =/
YOU AGREE TO BE BOUND BY THE TERMS OF THIS EULA BY INSTALLING, COPYING, OR OTHERWISE USING THE SOFTWARE. IF YOU DO NOT AGREE, DO NOT INSTALL, COPY, OR USE THE SOFTWARE; YOU MAY RETURN IT TO YOUR PLACE OF PURCHASE FOR A FULL REFUND, IF APPLICABLE.
also look at http://linux.vandeplas.com/acer/winrefund.long.htm
and http://www.microsoft.com/windowsxp/home/eula.mspx
http://linuxmafia.com/refund/faq/
Its hard, but its worth it.
Or just build your own computer.
Btw I'm still using Fedora Core 5
