Foundry: How to Build a Burner (Natural Gas) by jedi_knt
I'm fairly new to the whole casting bit, just got my foundry up and running a month ago. It took me about six months to figure out how to build a natural gas burner, do to the lack of instruction on the web, so I figured I'd throw in my two cents and show how I made mine.
What I'm posting is what I've learned through trial and error. If anyone has more information or ideas I'd appreciate it if you would let me know.
That being said, I'm not responsible for the actions or ideas of anyone that reads this. There is always a risk when working on "diy" projects, especially those that involve fire. Please practice safety when engaging in any type of casting or metal work.
Step 1: Background
Just a bit of background to explain why I made the burner the way I did.
First off I'm a college student, (i.e. broke) I had to use what was readily available to me, so propane was out of the question.
The natural gas line that I had access to was only 5 psi @ 3/4", so I needed a forced air system.
I had bought the foundry (minus the burner) from a blacksmith shop I go to on the weekends, so the inlet diameter on mine was preset at 1.5" with a 1" hole going into the brick work. It's inside diameter is 10" with a 12" depth. The crucible I have is an A10 (7 5/16" inside height, 5 11/16" inside top, and 3 3/4" inside bottom; holds about 1.5 L)
curvy77 says: Nov 21, 2011. 7:16 AM
this is very intresting. im not gonna use this (no offense) cause i prefer more athentic means but the design is quite functinal. what are you using for crucible?
jedi_knt (author) says: Nov 22, 2011. 9:31 AM
Ceramic graphite I believe, i have a few of them lying around.
My brother and I have recently made a few tweeks (I havent posted it yet) that really beefed up the burner It will get the foundry hot enough to start meltin in 15min.
cfreitas says: Nov 11, 2012. 4:46 PM
jedi, could you give an explanation of the tweaks you made ? This would be very usefull. Thankyou.
jedi_knt (author) says: Nov 14, 2012. 10:24 AM
Ok so when I said we made a few tweaks we almost nearly redesigned the whole thing; for the better I might add. cheaper with less parts and more efficient. I meant to go back and update, but I got carried away with other things.
http://imgur.com/a/6kz5f#0
We replaced the T section with a 2"x8" nipple and welded a 1/2" black pipe to it. a 90 degree sits at the end of the of the black pipe in the middle of the 2" nipple the 90 is attached to an black nipple terminating at a 1/2"-1/4" reducer (the brass tip).
Depending on your need (forge/foundry) the nossel for the outer pipe can be changed out. I have to collect some pics to make a new tutorial. I'll get on it this week end.
cfreitas says: Nov 14, 2012. 1:57 PM
Thankyou so much for answering.
I gave some steps ahead and bought a Jacuzzi water cilinder from a deposit of scrap and it costed me only 4 US$ :) Its big enough to make a nice furnace. Already took it to a machinist here and asked him to make cuts and holes on it, and also to place iron bars down on it to make it moveable something like yours. Unhappily I dont have all the tools needed to it ( yet ) so I thought would be better to get some things made for someone more experienced then I.
I´m very concerned about the gas thing, hope I can get it to work at least reasonably with Butane gas.
I saw your pictures in imgur.com and I will be waiting for any news that you post.
Sorry for take your time.
And thanks again.
jedi_knt (author) says: Nov 14, 2012. 2:47 PM
since it sounds like your still gearing up you might want to look at this...
http://www.gasapplianceco.com/pdf/venturi_spec.pdf
http://shop.clay-planet.com/mr-750-venturi-burner.aspx
I just found out about them today, kinda wish i knew about it when I first started.
best of luck
cfreitas says: Nov 14, 2012. 3:11 PM
Yes, I see.
Its a little expensive to me this burner. I think I will try to keep it as cheap as possible. Will you still publish your changes here ?
jedi_knt (author) says: Nov 15, 2012. 4:15 PM
I'll probably wright up a new one based on the amount of changes we made
cfreitas says: Nov 11, 2012. 4:44 PM
Hi there. I like a lot your instructable, and like more the clean aspect of the result.
I suppose the natural gas you use is Butane, not propane, right ?
I only have access to Butane ( the one used in kitchens ) in tanks, so I think I could give this setup a try.
I just need to know if yes, this is butane gas.
Congrats, nice work.
jedi_knt (author) says: Nov 14, 2012. 9:59 AM
Sorry for the late reply...Butane is the fuel source I designed this thing to work off of a 5 psi gas line, the one originally used for the barbeque.
The first fan I got was a little too powerful at 150 cfm though it will produce a good 18" long flame it occasionally blows out the flame; but I think that has to do more with the nossel size vs the foundry inlet than the fan. You might be better off with a fan some where in the ballpark of 100 cfm.
mcee2 says: Sep 16, 2011. 8:03 AM
This is a great step by step blog on how to make a burner. I had a little trouble with the plumbers tape, but got it figured out. Thanks a lot for the help.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
