3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fountain Pen Problems
Fountain pens float effortlessly over the paper when everything is working as it should. That is one of the reasons why people who prefer fountain pens really like them. But they can be difficult when something is not as it should be. They can be scratchy. Ink flows poorly or not at all. And, they may put out too much ink, even in the form of a sudden blob of ink that runs over a document and onto clothing. These problems are not inherent to all fountain pens, but occur in pens needing a little tender care to keep them in sound working condition. Fortunately, all of this is much easier than a person would think.
The pen shown is from a Classic American kit sold by Woodcraft.  The pen is reminiscent of a Parker Duofold from the late 1920's and early 1930's.  The color pattern is very similar to one used on Duofold pens.
Step 1Making it flow if dried out
A couple of Instructables advise soaking the nib and feeder (the section) in cool water for a day or so to remove old dried ink from the ink flow path or capillary system. Actually, a good flushing of the capillary system like this is advised every month. Another good practice is to add a little moisture to ink held in the nib and feeder that may be partially evaporated after a few days of non-use. Get a drop of water on your fingertip and touch it to the slit between the nib's tines.  If the pen has been sitting unused for more than a few days, add two or three drops of water,  Let it soak in. If you do not write with the pen immediately, the water can mix with the ink under the nib more thoroughly. Do this once a week and as necessary.
In more severe cases, as when ink has been left in a pen during several weeks of non-use, cup your hand under a faucet and fill it with water. Quickly dip the whole section into the water in your hand and remove it. Cap the pen and carry it in your pocket for an hour or so before using. If the writing is light in color, touch a facial tissue to the nib and feeder a few times to remove excess water or watery ink.
Fountain pens like to be used regularly.  If you are not going to use a pen for a while, empty the ink from it and flush the pen with water until no discoloration from ink appears.
Do not mix inks from different manufacturers.  They sometimes react with each other and form chunky, gelatinous material that clogs the ink passageways.   Use fresh ink that has been tightly capped or fresh cartridges.  Purists fill the air space in an ink bottle with an inert gas like nitrogen before putting the cap onto the bottle.  They do this to keep the ink from oxidizing.
40 comments
Oct 29, 2011. 5:57 PMlotus1922 says:
Great tutorial, I learned lots about how to keep my pens in shape that I did not know before. But I'm having a problem I didn't see addressed anywhere in here: I have Libelle fountain pen that I've always used a piston converter with. I last used it about two months ago and all was well, flushed it out like normal when I was done, etc. But now I have taken it out to use again with fresh ink (I never leave ink sitting in them), and the converter will not draw ink from the bottle when attached to the nib! The converter fills just fine when stuck directly in the bottle, but it does absolutely NOTHING when drawing through the nib. All the fittings check out fine and it has not undergone any trauma--- all it did was sit in its case for two months. What could have caused this?
Jan 31, 2011. 10:07 AMticoun says:
in fact, it was an adjustable flex nib, going from stiff to extra flexible
Jan 10, 2010. 1:12 PMdogianto444 says:
thank you! you have fixed my fountain pen!
Feb 12, 2010. 5:25 PMdogianto444 says:
what i did to fix it was do step7 and it worked realy well!!!
Dec 10, 2009. 11:42 AMsharlston says:
hey do you know what them catridges aqre called that are like a pump? you dip it in the ink and pump it and insert it like a normal cartridge?it looks like its made of chrome
Dec 12, 2009. 4:09 AMsharlston says:
ok thankyou
May 20, 2009. 6:06 AMThe ed says:
I have a parker fountain pen, which was my father's and it hasn't been used for quite some time(years maybe). now it won't suck up ink and write. What should I do?
May 21, 2009. 4:05 AMThe ed says:
I tried the method of dabbing the nib with a little water and it worked until the water dried up
May 22, 2009. 8:14 PMThe ed says:
ok. so I'll soak it for a few days. if it doesn't work, is it something else that is spoilt?
May 24, 2009. 4:04 AMThe ed says:
ok, I'll try it first
May 26, 2009. 4:02 AMThe ed says:
Hey, I think I broke the pump that sucks in the ink. Is it beyond repair now?
May 28, 2009. 5:38 AMThe ed says:
Ok. I don't know the model of the pen. I guess I'll just find some other way to use it. thanks for the help
Apr 26, 2009. 8:06 AMsharlston says:
like the pics u made on paint
Apr 27, 2009. 12:28 AMsharlston says:
good idea i will start doing that if you dont mind
Mar 22, 2009. 5:46 PMvitruvian8807 says:
Hey, how well do those disposable fountain pens work? I've been curious to try one and see the quality, but I haven't gotten to it.
Apr 26, 2009. 8:05 AMsharlston says:
can u really get disosable fountain pens and if you can where can you get them?
Mar 20, 2009. 9:52 PMvitruvian8807 says:
Eh? I've never had problems with my fountain pen. It's a "cheap" Waterman Phileas. I had one friend ask me if I had had problems like leaks. I looked at him weird, since I have never had problems. I guess I assumed fountain pens worked "perfectly". I find them to be amazing writing instruments. Gave my female friend an Audace Midnight pen. Too bad the only seller I've found was in France. Unfortunately, the bottom cap on mine was bitten by a kid (grrr!) so it's got long scratch teeth marks on it, and the clip on the cap broke off (also someone else). People just don't realize that they're not cheap. I don't think I can replace the caps without having to buy another pen, but maybe I'll save up and buy a Waterman Expert. I'm faving your 'ible and keeping it for future reference.
got the same pen as you
Dec 14, 2008. 6:04 AMItsTheHobbs says:
oh, I wish i could afford a Namiki.
Dec 14, 2008. 11:55 AMItsTheHobbs says:
ummm... yeah, sure... late teens..(cough,twelve,cough) yeah, I know. I can't wait until the day I get one though, when I have one thousand dollars to kill...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
475
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
