Step 10This boat is intended for flat water use and not for use in white water.
iImage Information
If the tarp is pinched between rocks and the boat's frame, it can be punctured. Two tarps layered or a nylon-reinforced tarp is stronger. However, since the blue tarp is easy to obtain and can be repaired with duct tape or with a patch of tarp material and silicon rubber as a glue, the blue tarp kayak makes a lot of sense for most conditions. Wear a life jacket at all time. Flotation devices such as inner tubes should be added inside both ends of the boat for additional safety. To make a stronger boat you can cover the frame with heavy coated nylon or vinyl. You can also make the frame of thicker wood. silicone rubber can be used to seal the gathering at the stern and bow by applying a generous amount between the layers before securing (this is not necessary unless you plan for the seam to be under water). This boat is intended for flat water use and not for use in white water. One reason for this is if the boat was crushed against a rock, the frame could collapse or brake pinning you in the boat and preventing you from swimming to safety and possibly drowning you.
And Yes. Always Wear a Life Jacket.
This is really a fantastic project - cheap, light on materials, easy to do, and yet it doesn't hinder the fun of using it in any way. Kudos!
