I got the idea for this after seeing Blue Buddha's Quantum Rose a little while back, and I wanted to create a simpler, cleaner version as well as respect their IP rights to that design. The nice thing about maille is that you can always add or subtract elements to suit your taste, making each and every design your very own. Plus, as this was a Mother's Day present for my mom last year, I wanted to make something special for her :) And true to that, I've only ever made one pendant with those lovely robin's egg blue rings.
As usual, feel free to ask questions!
Materials:
- Twelve 16 gauge 5/16" ID rings
- Four or eight 18 gauge 3/16" ID rings
- Two pairs of pliers (I like to use flat nose in my right hand and chain nose in my left)
- A bail of some sort, I used a spare 18ga. 1/4" ring I had lying around
P.S. If you're wondering why there's an extra "le" in chainmaille, it's the French spelling. Plus, it prevents any confusion between your works of art and those annoying emails you can't delete fast enough. xD
P.P.S. I'm only using four small rings in this 'ible because I don't have the exact components needed to make the double small ring version. Basically, because this process results in such a stiff weave, you need to have just a little bit of extra give to make it work. Unfortunately, I'm out of machine cut rings so I don't have that extra bit of leeway, and therefore making the version you see in the first few pictures is virtually impossible for me right now. However, the process is essentially the same either way.
If you're interested, what I've found works best is aluminum rings from TRL (the ring lord), bright or anodized, all machine cut. The reason for this is that the machines compensate for loss of material by rotating the coil of rings as they're cut. Saw cut rings, on the other hand, are fed through a very thin saw blade, but the thin blade still removes a bit of material, and this results in a marginally smaller ring. Normally this wouldn't matter, but on tight weaves, you better believe it does.
Visit Our Store »
Go Pro Today »
I'm guessing that the AR (aspect ratio) of the small rings you're using is too large for the large rings. If you take a look at The Ring Lord they post the ARs of all of their rings, so mine would be 5.3 for the big rings and 4.2 for the little ones. Once you've got that data, you can adjust accordingly: find the ratio of the wire diameters and work from there.
If you tell me what gauges of wire you have and which rings you're making yourself, I might be able to help you out :)
I added a few rings to tighten it up a bit.
Also made a color matched set of earrings using a simple box chain weave.
Thanks.
Don't forget to post pictures!
Great job. I really like how it turned out (especially with the blue). Very pretty. ;)
