3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Four port USB hub
Four port USB hub
This is a four port USB 1.1 hub built on a tweety bird theme.
Step 1Getting the components together
First, the USB hub controller. Texas Instruments make, among others, one four port USB 1.1 hub in a 32 pin Quad package. They call it the TUSB2046. That is the black square at bottom right, in the picture.
It needs a regulated power supply of 3.3 volts, supplied by a three terminal low dropout regulator. Microchip make one, called the MCP1700T-3302E/TT though the actual chip is a tiny thing. Look carefully, you might just be able to identify it.
The other components were salvaged from various sources. The 6 MHz Crystal came from a Television set, where it was clocking the remote control microcontroller. The capacitors and resistors were unsoldered from various boards from junked equipment.
31 comments
Sep 8, 2010. 12:14 PMHomerS says:
does there need to be a "system power on reset" ?? and what reset thing do i use. i found one that needs a sense thing using resistor, not sure what resistors to use.
Sep 2, 2009. 2:59 AMrajendra123 says:
ok
Apr 5, 2009. 9:02 AMchilll2009 says:
Can you buy the stuff at radio shack???
Nov 14, 2008. 3:43 AM9H1LO says:
can we have a proper schematic for this? i will gladly make a proper pcb layout
Nov 14, 2008. 5:08 AM9H1LO says:
there is lots of stuff on that datasheet i will try and remove what makes sense to me i already have the chip and i have MC33269DT33G as 3.3v regulator
Sep 10, 2008. 7:56 PMemmotic says:
I'm sorry im too stupid but, can you list the materials needed for this project? Thanks :)
Apr 11, 2007. 3:42 PMDael says:
So I recently switched from my PC, which has sadly died, to my laptop, and I am finding myself short of USB ports. I was thinking, "Hmmm, I need a USB hub, and it would be awesome to build one". So I come across your Instructable and think, what luck! I was just wondering though, would you be able to post a schematic?
May 9, 2007. 3:33 AMbinnie says:
its cheaper to buy one than make. plus eaiser!
Apr 11, 2007. 3:46 PMDael says:
Nevermind, found one. =)
I was being lazy and completely forgot to check the data sheet app notes.
Anyway, great instructable!
Nov 21, 2006. 7:06 AMmrmath says:
You lost me. I couldn't follow it. Not because it wasn't a good instructable. I hae to say, I think it is a good one. It's because it had too many big words my little brain couldn't handle! I'm a wannabe. I wannabe able to do this kind of stuff.
Jan 25, 2007. 11:26 PMbinnie says:
go back to geek school this is easy stuff the hardest bit about it is the smd
Jan 26, 2007. 6:09 AMmrmath says:
There are many different types of geek. There's software geek. There's hardware geek. There's electronics geek. Science geek. Star Trek geek.... Just because I don't/can't follow what he's talking about with electronics doesn't make me less of a geek. It just means I took a different curriculum when I went to geek school.
Jan 26, 2007. 6:56 AMbinnie says:
lol yea true true i fall under all those catagorys xcept the startrak one lol you sound a bit like my mum ( has a mental block on technology ) i havnt been to geek school yet, and im waiting till i leave school ( nother 4 years awww) But if your brain cant handle silly big words that make no sence to nobody why do you bother reading it. yes to learn good reason
Jan 10, 2007. 4:06 PMShriike says:
How much does this project cost? I was looking for a usb hub and this looks like it might be fun
Nov 23, 2006. 4:32 AMcold_fusion says:
Very nice, I have used FeCl before for etching but tend to use vero for projects because its nasty stuff. I would definitely like to see an instructable on your salt etching method. Keep up the nice project!
Nov 21, 2006. 7:43 AMPeterTheUnGreat says:
Does the etching process have advantages over the usual Feric Chloride method? If so I would be interested in seeing the instructable Pete
Nov 23, 2006. 1:05 AMThe Real Elliot says:
I messed around with this tonight, and all I got was rusty water! Does the copper board connect to positive (anode) or negative (cathode)? And do you think the salt concentration should matter much beyond conducting electricity? I'll play around some tomorrow, but I've got cooking to do too. -- Elliot.
Nov 22, 2006. 11:56 AMrotor says:
I'd very much be interested in an instructable on this. I've stayed away from pcbs because I have a tiny house with a small child, and I'm not real keen on keeping strong acids anywhere the kid could get to it.
Nov 22, 2006. 8:27 PMajelliot says:
Gotta know more about how you etched that board.
Nov 21, 2006. 4:34 PMThe Real Elliot says:
OK, I'll bite.
Table-salt-solution electro-unplating? That's freaking genius. How long does it take? Voltages? Etc?
I think you're right -- your method does need its own instructable. One reason I shy away from FeCl etching is the horrible chemicals, and what they do both to my sink and the environment at large. If you've got a better way, I'm dying to hear it.
Consider yourself cajoled.
Nov 22, 2006. 1:13 PMclothbot says:
Brilliant! Add me to the cajoling list too.
Nov 21, 2006. 8:38 PMVermin says:
That's the funkiest prototyping method! I second The Real Elliot's request.
Nov 21, 2006. 7:45 AMPeterTheUnGreat says:
I too liked the 'knocked up in my shed' aesthetic of the project. Nice. Pete
Nov 21, 2006. 6:23 AMellinger says:
Nice combination of old-tech and new-tech. Great re-use of parts. I fully expected to see a commercial hub disassembled and reassembled into the tweety bird. I am pleasantly suprised.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
70
Author:neelandan
Employed as an Engineer in Electronics. Interested in building small circuits around tiny chips (the electronic kind).
