Here you can learn how to program embedded Debian board Fox board G20.
http://www.acmesystems.it/?id=allproducts
Company has a nice webpage how to get started. Very quickly could get running webcam and Wifi.
To make it ieasier to repeat you can go through the notes in the attached files.
Webcam resolution is 800x600, can connect a motion detector to GPIO pins, set up a webserver, there is a built-in support for 1-wire temperature sensors.
Dissadvantages: no Kernel header sources available. It was for me too hard to compile own Kernel module for example for another WiFi stick. And, secondly, during continuous operation a SD card error appears after some hours. Power-off restart using a wallplug timer every 3 hours helps somehow.
A link to my webserwer where the data are served by Foxboard is here:
http://foxboaard.host22.com/
It is good for education to learn to control something with Linux. Because of that and also the price of 139EUR, would recommend to use NanosG20 instead of Foxboard. If power saving is not an issue, then would use Ubuntu on a netbook, because every Linux board is somehow tweaked, but on notebook Ubuntu just everything work. For home use most economic power-saving option would be to put webcam & data server in the router, for example using OpeWRT in WRT160NL.
02 date time set.txt114 bytes
02 shell in the box.txt961 bytes
03 change hostname.txt350 bytes
04 automount USB stick.txt1014 bytes
05 cgi.txt636 bytes
07 GPIO motion detector webcam.txt829 bytes
09 WiFi RTL8188 works.txt607 bytes
12 interrupts.txt735 bytes
Not Nice
Visit Our Store »
Go Pro Today »
