3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Frame for installing Christmas rope lights on ridgeline of roof
We love using rope lights for external Christmas decorations - they look smart, are reliable, and easy to store.  The downside is in installation.  You can buy multi-purpose plastic clips that work with all lighting systems (C9, C7, mini-lights, rope lights, etc) that work great for installation on gutters and the edge of the roof, but are a real pain on ridgelines.  The only way to install these are to slide them under the shingles which starts separating the glue and causing them to lift.  They also orientate 90 degrees in the wrong direction and so you end up having the use some other means to attach the rope lights to the clips (assuming you are running along the apex of the roof).
This project builds a simple frame from PVC pipe that stands the lights off the roof itself, and provides an each mounting surface for the lights.  It also guarantees the lights will be in sharp, straight lines which makes your house look all that better when lit up at night.
Step 1Materials needed
Materials:
1/2 inch PVC pipe (schedule 40)
1/2 inch PVC "X" fittings
1/2 inch PVC "T" fittings
1/2 inch PVC 45 degree "elbow" fittings
1/2 inch PVC 90 degree "elbow" fittings
Plastic cable ties (I buy them by the bag of 1000)
Tools:
Tape measure
Marking pen or pencil
PVC pipe cutter
PVC glue (optional)
Estimating of quantities:
I cut my PVC into no longer than 5 foot lengths to prevent sag.  You could increase this, but may see sag, or reduce, but use more fittings.  The following is a rough estimate of how much material is needed.  For ease of terminology I will call the stands at the end of each ridgeline run an "End Stand" and the intermediate stands an "Internal Stand".  End and internal stands are built the same way, they use either a "T" fitting (end stands) or an "X" fitting (internal stands) and 2 x 45 degree elbow fittings.  Each stand uses 15 inches of pipe - 2 x six inch legs, and 2 x 1.5 inch pieces to join the T/X fitting to the elbow.
Calculate number of stands:
2 x end stands
1 x internal stand for each whole 5 foot length of the ridgeline (subtract one if length of ridgeline is exact multiple of 5 feet)
Calculate total pipe needed:
Length of run on ridgeline + (number of stands x 15 inches)
Calculate number of fittings:
2 x T fittings (one for each end)
1 x X fitting for each internal stand
2 x 45 degree elbow fittings for each end and internal stand
Example:
Assume a ridgeline of your roof is 23.5 feet long.  You will need:
2 x end stands
4 x internal stands
Fittings will be:
2 x T fittings
4 x X fittings
12 x 45 degree elbow fittings
Pipe will be 23.5 feet + 7.5 feet (6 x stands x 15 inches per stand) = 21 feet.
Exceptions
If the length of the ridgeline is just slightly more than an even multiple of 5 feet (like 16 feet) you may choose to remove the last internal bracket and cut the last piece of pipe to a longer length (6 feet).  If two ridgelines meet, you may choose to join them if possible using an appropriate fitting instead of building the end stands for each end.
1 comment
Dec 21, 2011. 10:51 PMl8nite says:
neat idea
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:ORDuckFan
