Introduction: Frayed Denim Quilt
I love to make quilts, especially ones that don't require batting, hand sewing and finished edges.
This instructable will show you how to make an easy frayed denim quilt that you can size to fit whatever bed, couch, wall, etc. that you can imagine. It does take some sewing abilities but can be completed without too much effort and time.
Step 1: Step 1: Materials
Here is a list of all of the materials that you will need.
6 yards denim or scrap blue jeans
6 yards of your choice of fabric for back (I used flannel cut from an old shirt)
Matching thread
Scissors
Denim needles (also called jean needles)
Sewing machine
Before you get started, make sure that your sewing machine is threaded correctly and that you have tried the thread and stitching on scrap pieces. Easier to make a mistake on scrap and the fix than to try to fix the pieces that you are actually going to use.
Step 2: Step 2: Cutting Material
This quilt is made from fabric squares that are denim and some other type of fabric, usually flannel (this makes it nice and warm). Each square is cut to 6 1/2 in. This leaves 1/2 in seam allowance to make the fray at the end. You then stitch squares together to make strips and then connect the strips together to get the size that you desire. The materials listed are for a 12 X 15 square quilt (180 squares total). You can scale this to fit your desired length and width.
Start by cutting the number of squares that you want for your project. I measured a Full Size comforter at 78 X 88. When divided by the completed square size (5 1/2), I would need just over 14 squares and exactly 16 squares. I like my comforters on the big size so I would probably measure out this quilt as 15 X 17 squares at least if not a little bigger.
Remember to cut out the same number of denim and fabric squares.
Helpful hints: When using new flannel (or new anything), safe bet is to prewash so that the material is preshrunk and you get rid of a lot of fuzzies. Also, if you are using old flannel and denim like I did, iron material flat to press out wrinkles that could hinder in sewing the material, especially flannel because of the stretch.
Step 3: Step 3: Assembling Quilt
To begin assembling the quilt, place 1 denim square on top of 1 fabric square with the wrong sides together. When you look at it you should be able to see the right side of the fabric from either side. Place together all of your squares the same way. See the first picture for a visual.
Next take 2 sets of your squares and place the back pieces together so the 4 squares of material look like a sandwich with the two denim pieces on the outside (Picture 2). Stitch across one end with either a double stitch or a stretch stitch. Make the seam 1/2 in. from the edge. Open the fabric so that the seam stands up and both pieces of denim are on top. (Picture 3)
Step 4: Step 4: Assembling Quilt Cont.
Next take another set of the squares and lay them back to back against the piece you just sewed together. Stitch here. Open these up just like before. Continue to put squares together like this until you reach the desired length for you quilt. You should now have a length of squares connected like the top strip in the second picture shown below. Set this length of quilt aside.
Continue to make additional strips the same way. Make each strip the same number of squares long. When you have completed the desired number of strips, you will be ready to connect the strips together to complete your quilt.
Step 5: Step 5: Sewing Strips Together
Lay 2 of the srips from the previous step back to back. When you sew these together you will need to make sure that the seams of the squares are folded in opposite directions. This is so that your needle does not have to sew through too many pieces of denim and will make trimming later easier.
Make a 1/2 in seam from one edge the entire length of your strip. Continue to connect each of the remaining srips the same way. After you have connected all the strips to make your project your desired size, place a 1/2 in seam around the entire outer edge.
Step 6: Step 6: Completing Quilt
After connecting each row of strips, your quilt should look like the illustration in the second picture below. To complete the project, you must clip the raw edges on top to give it the ravelled look. Notice yow the seam of the top left corner is folded back to the left. The seam on the square just below is folded to the right. You did this when you stitched the length of strips together. There is also a seam line the entire length of each piece. In the corner of each square, your seams have created a smaller square (notice the first square in Row 1 of the illustration).
You need to carefully cut each of these little squares out. Clip on both sides of the seam where the little square is being held down. This will let the square stand up so you can clip by the center seams. The boxes in Row 3 of the illustration are what it should look like after being cut out.
After clipping out ALL of the squares, start clipping all of the exposed seams approximately every 3/8 in to 1/2 in. No need to measure. Just approximate where the next cut should be to make the cuts uniform across the length. The first square in Row 3 of the illustration shows this step. Also clip all of the edges around the outside.
After you've completed this, the next step is to wash your quilt. (I also take the quilt outside and shake to remove any loose threads.) Washing the quilt will fray the edges. It will continue to fray in the dryer. CAUTION: If you place this quilt in the dryer, you should check and clean out your lint filter every few minutes until quilt is dry. There will be a large amount of loose threads that will plug the filter if you do not check it.
The point is to fray the quilt. The more frayed it is, the better it looks.
Have fun with this project.
Most of the instructions came from a Bonnie B. Buttons pattern #2500.
Bonnie's Country Creations
1466 Alcona Dr.
Burton Mi. 48509
1466 Alcona Dr.
Burton Mi. 48509
Step 7: Variations
There are all sorts of variations of this quilt. I think the quilt looks better if you mix light to dark denim. Also, you can change which piece of fabric is on the top if you would like. I personally like the looks of the full denim with the bit of color that shows when the seams are frayed.
Go crazy and create your own version.
