3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Frayed shoe lace fix
Frayed tips on shoe laces is about as annoying as things can get. Forcing the little ends of the shoe lace through those tiny holes can sometimes feel hopeless when everything is coming apart and bunching up. I've found a pretty effective and simple fix that takes a few a minutes and costs just a couple dollars.
Step 1Gather materials
Gather materials
To fix the shoe laces I needed a lighter, a scissors and some heat shrink tubing. I bought an assortment pack of heat shrink tubing and ended up using the ones that were 3/32" in diameter. You might want to pick up some bigger or smaller tubing depending on how frayed your laces are and what size they are.
19 comments
Dec 12, 2006. 5:52 PMmikesty says:
Aglets, how awesome! There was an article on Digg about "33 things you never knew the name of", and this was the first one.
Nov 14, 2010. 3:45 PMbo88y says:
"Aglet" is a subspecies of the broader and slightly more familiar category, "ferrule." Damned useful things, in any case.
Did your Digg article mention "philtrum"?
Dec 13, 2006. 3:20 PMdsadinsky says:
only costs a couple bucks? shoe laces only cost 99 cents. talk about missing the big picture...
Jul 8, 2010. 1:26 PMstructuresound says:
I think that's actually only about a nickel or dime worth of heatshrink. A couple of bucks if you don't already own a hairdryer or bic lighter.
Aug 19, 2010. 1:52 AMMerteuil says:
Waxed laces for dress shoes--along with fat laces--tend to cost a lot more than 99 cents. When did he last buy some? The eighties? Today, if we were to buy some, there's no way that they would last Long enough to consider repairing even te frayed ends... Awesome and direct instructable. Thank you!
Jul 8, 2010. 12:52 PMCreaturiste says:
Looks very neat, I must say. Very prscytical if you already keep shrink tubing in your inventory. Yet, for those who don't, we can fuse the ends of shoe laces very cheaply and quickly with hot glue. Apply to and around the tip of the frayed lace, then quickl;y roll it more precise with moist fingers that have been dipped in water.
Jun 18, 2007. 11:45 AMzanfar says:
Add some Paracord/550 Cord http://www.supplycaptain.com/store/index.cfm?fuseaction=category.display&category_id=19 and you have yourself a complete DIY shoelace that will last for years.
Note: if you use paracord, you can dispense with the shrinkwrap, paracord fuses on it's own when subjected to high heat. It won't look as good, however, so I would do both.
Jul 26, 2009. 10:41 PMOryctolagus habilis says:
ALso, it would give a bit of a stiff end for going through the eyelets. I found that when I fused nylon laces to fix them that I had to slightly melt about 1/2" up from the fused end just to stiffen it, but this would be nicer.
Dec 31, 2008. 8:19 AMPatented says:
Thx my hockey skates laces were like this this trick help me alot!
Oct 2, 2007. 7:17 AMblodefood says:
Very neat! I shall pass this on to my friends at Shoelace CollectiveShoelace Collective. This totally fits in with the purpose. When you really need to keep a pair of shoes on your feet, a pair of shoelaces kept in good repair will go a long way to get you where you are going!
Sep 3, 2007. 2:01 PMkoolmuffin13 says:
if its nylon you can just use the lighter
Dec 14, 2006. 7:58 PMarmoty1 says:
perfect idea , in egypt we call it "selk mecrona" (the shrink tubing) 3DC EJC1HFG
Dec 14, 2006. 12:21 PMhollasch says:
I also use fingernail polish to cure frayed ends; works just as well. Let some of the polish wick into the lace for a very firm end. They'll never fray again after that.
Dec 11, 2006. 6:36 PMTheCheese9921 says:
shhhwwweeeet but what are those thingys called?
Dec 12, 2006. 8:20 AMCementTruck says:
Flugelbinders! - According to Tom Cruise, in the movie "Cocktail. That's probably what they're called on his planet. :)
Dec 11, 2006. 8:02 PMLasVegas says:
Dec 18, 2009. 6:57 PM.happy.hippie. says:
i was wondering if i was going to be the one to tell everyone they're called aglets
Dec 12, 2006. 7:20 AMPeterTheUnGreat says:
What a good idea! I have lots of annoying laces and lots of heatshrink - time to get them together and make swwet music. Pete
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
882
Author:noahw
Editor of the Workshop and Outside channels...I'm back!
