Free DIY Headphone Wall Mount
671
17
4
Published
Introduction: Free DIY Headphone Wall Mount
About: Student Pilot, Audiophile, A Very Bored Thinker
Welcome ,
Now you must be thinking, what in the hell does he mean by free and why is this fishy. I PROMISE YOU , by the end of this short guide, you will be running to get this thing up ASAP.
Now this is my first Instructable so cut me some slack since i might not know how the format works , but il make it as simple and easy as possible.
Materials Needed :
1 x Any Cardboard Box Lying Around which is preferably Double Layers ( like your amazon delivery boxes ) but pretty much ANY cardboard box would work.
1 x Double Sided 3M Tape ( i cant stress how important it is that this tape is 3M or something equally strong )
1 x Scissors
1 x Super Glue / Quick Fix ( also useful to have resin glue if possible to help but not neccesary )
Optional
Acrylic Paint of Choice
Peace!
Step 1: Cut Out the Box to the Portion Shown
Take the Cardboard box and Cut our a Portion like in the picture,
You dont need to be THAT precise in your measurements but if you really want to then keep the middle board as a 2/4th ratio to the side boards as a 1/4 ratio.
Step 2: Make the Sheet Flat
As in the Title , nothing fancy happening here.
Step 3: Create Grooves in One Portion of Strip
Well. for this you can use the tip of the closed scissors or your nails itself.
make sure to make only a few grooves on the left and right side , and keep the center area flat
Just create Grooves as shown ( This is to help in bending the cardboard to the shape of the headband later ).
Note : Make Equal amount of grooves on the left and right side
Step 4: Cut Triangles Towards the Main Board As Shown
Cut the Triangles in a 45 degree angle the bending line.
Note : Do not exceed the groove lines
This is so that when you curve the piece and bend it, it will fit perfectly with the main board.
Step 5: Bend Side Board to the Main Board
Once Done Correctly ,
Bend the Side Board as shown in the picture so that it fits as shown to the main board.
Use Super Glue to secure the side board in place to the main board.
*Can use a glue gun to help the super glue too
Step 6: Bend the Other Side Board to a Triangle With the 1st Side Board
Now Bend the Other Side board so that the curve will be flat on the side board.
Now SuperGlue it Together and Make sure to use a strong Adhesive here too.
*Glue gun can be used to help the super glue
Step 7: Use Double Sided 3M Tape ( or Any Other Equally Strong Tape )
Use Double Sided 3M Tape ( or any other equally Strong Tape ) on the Back , This is the most crucial, as using any other tape would be disastrous as the mount would just fall off,
I have used just two strips but you can use more for more peace of mind.
Step 8: Step 8: Mount on the Wall!
Now is where you can Paint it whatever color you want, and Mount it to whatever wall you want,
Tips:
1. Paint with Acrylic , since i've observed that it provides a bit more friction for the hanging headband.
2. Keep a small weight on top for a day before putting your headphones, to check if it will hold without problems. if not, use stronger adhesive and tape.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    4 Comments
    Made one this morning, could not find the glue, used tape :-). Great idea!
    Hi @roberti55! that's great!, although , i hope the tape was strong enough to hold your headphones up? . send out a picture of it . would love to see it in action :)
    Oh Yeah that too ! And Saw your profile, you've done some amazing stuff man, Cheers!
