Free Energy Solar Powered Radio
Published
Introduction: Free Energy Solar Powered Radio
About: Hello friends i show how to make stuff with no skills easy to replicate step by step from powerbanks,generator,invertors and so on thanks
Free energy solar power radio diy https://www.youtube.com/watch?v=XtP7g...
is an easy project to convert an old battery operated the radio in a solar powered radio that you can call free energy because it uses no batteries and it operates when is sun and with the help of solar panel converting the solar power in dc electric power.This video was filmed in eastern Europe Romania and i will like to thank youtuber victor's channel https://www.youtube.com/watch?v=HVJ1z... and i did put her video in this solar energy radio i hope she will be alright with it thanks. Going back to our free energy project you will need 6v 1w solar panel and a 9v or less radio and you are set in any location you can hear local am/FM radio battery free. Solar panels absorb the sunlight as a source of energy to generate electricity or heat.
A photovoltaic (PV) module is a packaged, connected assembly of typically 6x10 photovoltaic solar cells. Photovoltaic modules constitute the photovoltaic array of a photovoltaic system that generates and supplies solar electricity in commercial and residential applications. https://www.youtube.com/watch?v=1o1QZ... https://www.youtube.com/watch?v=G4erc... https://www.youtube.com/watch?v=2q5Ki...
Step 1: How to Convert Your Radio to Solar
Hello friends i will present today how to convert any radio dc powered (battery operated) in a free energy solar powered radio that can be used all over this planet the only condition is to be sunny and maybe in the future we will modify this with a power bank to store the power and run the radio and when is cloudy BAMMM run of the battery power bank or 18650 .
Step 2: Choose Your Radio
For this project almost any radio dc powered will work an USB one is best but in the video from the end of this tutorial i used a 9v dc radio powered with 7.2v at 0.10A and you can go as low as 5v you have to adjust your panel according to your panel we did manage to find this 6v 1w panel but the ratings are overrated but is gonna do the job.The first picture is the plus + and the minus - of the radio, this is the only tricky part to find the terminals of the radio because any radio has the pins +/- indifferent position but tested with a 9v battery the easy way normally (but not a rule) is the diagonal terminals.
https://www.youtube.com/channel/UCPjqH3HfNA4Shttkx1haAUQ
Step 3: The Solar Panel
A photovoltaic (PV) module is a packaged, connected assembly of typically 6x10 photovoltaic solar cells. Photovoltaic modules constitute the photovoltaic array of a photovoltaic system that generates and supplies solar electricity in commercial and residential applications. Each module is rated by its DC output power under standard test conditions (STC), and typically ranges from 100 to 365 Watts (W). The efficiency of a module determines the area of a module given the same rated output – an 8% efficient 230 W module will have twice the area of a 16% efficient 230 W module.
Step 4: Measurements
A solar cell, or photovoltaic cell (previously termed "solar battery"), is an electrical device that converts the energy of light directly into electricity by the photovoltaic effect, which is a physical and chemical phenomenon.
It is a form of photoelectric cell, defined as a device whose electrical characteristics, such as current, voltage, or resistance, vary when exposed to light. Solar cells are the building blocks of photovoltaic modules, otherwise known as solar panels.
https://www.youtube.com/watch?v=XtP7gCpc2Ck
Solar cells are described as being photovoltaic, irrespective of whether the source is sunlight or an artificial light.
With the help of a multimeter you will find the terminals of the solar panel and connected according to polarity +solar to + radio and -sola to -radio and if you want to be more mobile connect some crocodile clips to make the connection.
Thanks for your time and check the video for more details and proof all the best
    • Woodworking Contest
      Woodworking Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    Small solar panel free energy available everywere
