3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Free Laundry Hack
Step 2Moment of truth
now that you have your sticks, stare the washing machine down until all worries are pushed aside. First experiment with the metal coin inserter mechanism where you normally place coins on. When it is empty, push it in until it stops (about half way).
Hold it in position while you grab your stir sticks. Slowly pull the tray back no more than 1cm and hold it there. One at a time, insert a stir stick into each slot at a 30-35 degree angle and push it in until it fits snugly into its position. (I find that it works best when its less than 45-degrees).
Once each stick is each coin slot, push the tray in a little bit more so that it's almost all the way in, and hold it there.
This is the tricky part. You will need to gently push the sticks further into the slot, still keeping them at 30-35 degrees. At first, it may seem like they don't go in further, but with practice and some adjustments, you will find that they can ease another 0.5cm or so deeper. Do this for each stick. (This step took me ~5 mins the first time I tried).
1 comment
Nov 14, 2007. 12:35 PMtpastrana199 says:
hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm.......................................................................................... i should tell my mom to do this. this might also work for a pop dispenser or a snack machine. thanks.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:robshere
