Introduction: Free Light-Emergency Light
Picture of Free Light-Emergency Light
I love free energy,...this wont save the world but it may help
You need a Peltier Tile, LED's, voltage booster, wires, thin aluminum and a tiny vice
Step 1: The Power
Picture of The Power
Wire the Peltier Tile to the booster, and the booster to the LED's
Peltier tiles will take temperature differences and create electricity.
Step 2: Find a Hot Spot
Picture of Find a Hot Spot
Once wired together find a hot spot in your house,....I used the hot water pipe in my basement.
Place the hot side of the tile on the hot pipe.
Use the thin aluminum to hold the tile to the pipe, this also acts as a cold side extension, then use the vice to take away slack!
Every time my pipe gets warm the light turns on!
ironsmiter (author)2015-12-22
while the Peltier Tile may work... you could get much better results out of a TEG. Their generating efficiency is MUCH higher( though much harder to find in junked electronics :-)
Add a heatsink to the cold side, and use a less/non conductive clamp(velcro, zip tie, even a large wire twist tie should work well for hot water pipes) for even better results. that way the cold side isn't getting warmed through conduction from the strapping.
Awesome idea, to let you know when someone has used up all the hot water, while you are working in the shop. If the light goes out? just stay dirty... it'll be a while before the hot water tank reheats for your shower.
GyroHeat (author)ironsmiter2015-12-22
I do love these things,...while a TEG is more efficient .....it so only in super high heat applications. The TEC is way better at these low temps...ie.90 f. maybe I should post my TEG lamp for use in campfires!
About This Instructable
1,030views
10favorites
License:
Bio: Self learning person dreaming of engineering
More by GyroHeat:CNC Wood ArtRolled Garden Beef....Smoked & GrilledGarden Hot Sauce
Add instructable to:
