Free Rechargeable Flashlight From LEDs and Lithium Battery
2,242
26
4
Posted
Introduction: Free Rechargeable Flashlight From LEDs and Lithium Battery
Update: for my first test the flashlight laster 24 hours and 7 minutes before it needed a charge.
Building a long lasting, rechargeable and powerful flashlight is easy and cheap. I only used the following.
An effervescent table bottle
6 LEDs taken from broken christmas lights
1 18650 used laptop lithium ion battery
A switch
22 gauge wires
Step 1: Building It
Cut a small hole for the switch. Run wires through the hopes to connect the battery, switch and LEDs together. I used an electrical crimp connector to hold all negatives of the 6 LEDs together. I then soldered 2 sets of 3 positive LED wires together. I then installed the LEDs in the bottle lid. I soldered everything together.
Step 2: Trying It Out
The flash like works really well. I wrapped the battery in cloth so it would fit snuggly and would not move in the bottle.
The light is very bright. I installed no focusing mirror so the light is very spread out.
To check the voltage or charge the battery pull the switch out a little from the bottle to expose the terminals. Connect before the switch and the positive of the LED. Connect this to a wall charger. This allows you to charge the flashlight and check the voltage of the battery with the LEDs disconnected.
Step 3: Charging
I added two small charging wires (one before the switch the other on the positive before the LED).
I can simply hook up alligator clips to the wires to charge. I do need to have a timer and check the voltage often so it isn't over 4.2V. I can easily check the voltage of the flashlight without opening it using the charging wires to make sure the voltage doesn't get too low.
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    4 Comments
    i recommend these http://www.ebay.co.uk/itm/Li-ion-Lithium-Battery-Board-Charger-Li-LED-Board-5V-1A-Mini-USB-Board-/281594929179?pt=LH_DefaultDomain_3&hash=item41905da01b they have charger and protection circuit all in one also a rister on the led will stop over current and wasteing alot of power by heat
    Nope just a 5v 350ma transformer. I think its pulling about .7a it seems to work. I have charged over 200 18650 batteries and have never over charged any. I will be building an Arduino charging circuit soon.
    i hope your using a porper charging circuit to charge this
