Free Up Drive Space in Windows 10 Using Disk Cleanup
Published
Introduction: Free Up Drive Space in Windows 10 Using Disk Cleanup
About: working with IT ,its my main hobby
Cleaning the hardrive does not require using third-party tools. It can be done quickly using windows 10 built in app called “Disk Cleanup” and its free.
You will need the following items before you begin:
1) Deskop or Laptop
2) Windows 10 installed
3) Non- network Login ( personal not corporate managed)
4)Administrator access to PC that will be used
By the end of this tutorial, your hard drive will be cleaned up and much needed hard drive space with be restored . The reclaimed space can be used to store files , photos and more.
DISCLAIMER: This Instructable is provided for information purposes only, by DDruckenmiller., The reader should understand that using the outlined method to free up space and if used by an individual and or / the reader should any and all losses, injuries or damages incurred by or resulting from the use of the information in this publication are the sole responsibility of the reader and end user, all of whom voluntarily, expressly and completely release, forever discharge, and agree to defend, indemnify and hold harmless DDruckenmiller, from any and all claims, demands, or causes of action, which are in any way connected with the use of the information contained in this publication, this is and educational example only, if you hesitate on what to do then call a professional to assist.
Step 1: Where to Find the Application in Windows 10 `
Step 2: Click on Disk Cleanup
Simple step to launch diskclean up , Just double click to start the process
Step 3: Select the Drive That Needs Cleaned Up
A) After Disk cleanup opens ,it will ask what drive ( most PC’s use drive “C” as default)
B) Use the arrow to select a different drive if needed
C) Click “Ok” to continue ( At this point no changes have been made to you PC)
Step 4: Select Options Before Continue to the Next Step
Select all check boxes then select Clean up system files, this is the place you will recover the most space.after cleaning options are checked click OK and the application with run .
Step 5: Preview Options Before Clicking Next
As you can see , in the example I can recover over 1.6GB of hard drive space after the utility is ran. Click Next to process options and delete space. At this point NO data has been deleted click "OK" to continue.
Step 6: Caution at This Point Data Will Be Deleted If You Continue and Start Running Process
At this point files will be deleted and be unrecoverable if you continue. Click “Delete Files” to start disk cleanup.
Step 7: Final Step Let Process Run ,windows Will Close Then Reboot PC
When this window closes the process is complete and a manual reboot should be done.
Enjoy the extra recovered space.Click the video if you need help following the steps.
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Microcontroller Contest
    2 Comments
    Valuable info, Windows update files can really start to add up.
