Free Wire Twisting Jig
I needed to neatly twist some small gauge electrical wire for a project to neaten the wiring. As I was sitting around waiting on some other stuff, I decided to make a wire twisting jig out of a paperclip and a coffee stirrer - two items that should be "free" to anyone who works in an office. The only tools needed are a small pair of pliers, knife or scissors, and some tape (and the wire, of course). I just used my trusty Swiss Army Knife.
It worked great!
I made two versions, one for twisting two wires and one for twisting three wires. The three wire one is documented here.
Step 1Materials
Materials
Large paper clip (or other suitable stiff wire)
Coffee Stirrer (must be hollow)
Pliers, scissors, and/or knife (Swiss Army Knife, preferably)
Tape
Small gauge wire to twist (I was twisting solid insulated wire-wrap wire, 30 gauge)
42 comments
1-40 of 42next »
Jun 29, 2010. 5:20 PMSchooniedude says:
couldn't you use your drill?
Jan 14, 2010. 9:39 AMdewexdewex says:
Cut a 4 inch diameter disc of 6mm plywood with an  100mm M6 bolt secured in the centre with a nut and a washer. Slot the disc radially from the cirumference at  30 degree intervals with a tenon saw to a radial depth of 10mm. Drill a hole of about 5mm diameter at the bottom of each slot. stick an eyebolt in a vice, then thread a continuous strand of wire back and forth between the slots in the disc and the eye up to as many times as the number of slots will allow, secure the two ends of the wire at the eye bolt, stick the end of the bolt in a drill chuck. wind it up, and cut it off. You can have from 2 up to 12 strands. Obviously, subdividing the disc further will allow more strands.
May 18, 2010. 5:36 PMthink3000 says:
You should make an instructable about that. Or maybe you already do?
Nov 17, 2009. 3:40 AMthrobscottle says:
This is sooo cool!  I'm well impressed.  Now that I've read how to use it, I would suggest one improvement (don't know offhand how you'd do it, you'd need a more complex twister) - if the individual wires were able to rotate freely (eg by hooks that could turn) - you'd get a self supporting twist (this is how rope is made) - ie less inclined to come undone.
Aug 2, 2009. 2:48 AMSoDDiggerCpl says:
You know, the easy way of doing this is to tie the ends of one side of the wire to a key chain or carabiner, and hook that to something, and stand on the other side of the wire with a cordless drill. close the chuck of the drill so the three prongs grab the end of the wire. stand back so the wire is taught, and then start drilling. end of instructable. Why does everyone want to do it the hard way?
Sep 24, 2009. 10:15 AMScottSEA says:
There is more than one way to skin a cat. What if you have no drill handy? What if you're teaching a kid how to make something cool and useful? It was a well-written instructable that creates a useful tool.
Aug 26, 2009. 1:13 PMBraunchitis says:
I like using a hand-held mixer (the kind you use in the kitchen) for this. Wrap your wires to a door knob or whatever. Attach the other end of the wires to the mixer paddles. Then turn it on slow speed and let it do the work. Works quickly and twists the wire uniformly.
Aug 2, 2009. 3:08 AMNucleus says:
I have the same multi tool :)
Jul 20, 2009. 8:16 AMRedgerr says:
pretty smart, it came out of nowhere lol.. i was like.. whats going on.. huh?... then OH YEAH there it is! thats smart O_o very nice
Jul 7, 2009. 3:33 PMMicksta says:
awesome idea! and i guess youve got a victorinox champ ive got a climber which has less than half the amount of functions but still one of the most useful things i have. i just can't imagine myself walking around with something that big.
Apr 1, 2009. 8:29 PMDELETED_gabethegeek says:
(removed by author or community request)
Jul 5, 2009. 12:46 PMTheGeekFather says:
cordless screwdriver and an add on chuck works pretty good instead of a drill. It's a lot easier to stop in time. Think the chucks sell for 15 at home depot. You can pick up a cordless screwdriver for 19.99 at most hardware stores.
Jul 2, 2009. 11:03 AMavwos says:
Such a simple concept, but so frickin' useful!
Jun 29, 2009. 10:38 AMbobank says:
This is the way how genous think, I was always excited and real admirer of people that can invent some jig that there is no any preknowlege needed, just pure inteligence. If you ever tested you IQ, I bet it is high. Maximus
Jun 24, 2009. 7:24 AMLauraLarsen says:
Very nice, can also be used for jewelry work. Thanks for the tip!
Jun 18, 2009. 7:18 PMlbrewer42 says:
Great idea. I admit though, I just tend to use my cordless drill. I measure the length of wire needed (plus a guess at the extra length lost by twisting), clamp the wire in my vice, put the other ends of the wires into the drill's chuck, and let the drill do the work. Makes great twisted wire. However, since your method can be done just about anywhere - I like it!
Jun 12, 2009. 8:43 PMjaime9999 says:
If you want to be really fancy, you can twist the strands together around each other without twisting each wire itself. This is how twisted rope is made.
Doing so might have benefits for this application using metal wire, since too much twisting or other mechanical stress weakens metal, especially ductile metals like copper and aluminum. Of course that is negligible for short lengths, but might be significant if the twists were tight or the length a half foot or more.
Easy enough to implement a rope-twisting machine http://www.instructables.com/id/Reuse-old-printer-ribbons-and-video-tape-to-make-r/ your way-- just use paperclips and bits of wood or cardboard.
Jun 4, 2009. 11:40 AMaltrobot says:
This makes me regret even less buying this : http://www.thinkgeek.com/gadgets/tools/8b97/
May 24, 2009. 11:10 AMFast Eddie says:
Holy MacGyver! A paper clip and a straw. LOL If this problem ever arises for me, I'm coming straight back here. Ingenious!
May 26, 2008. 9:06 AMM F says:
my boss got us all a LEATHERMAN TOOL. I thought "I'll never use that! now much wiser. my LEATHERMAN pouch is wearing out. I need to find a good Instructable for making a new one
Jul 7, 2008. 8:46 PMbillybobjhonson says:
wow, random
May 17, 2009. 8:17 PMdata23 says:
2 things, if i ever need rope, and i have a paperclip, no need to revisit the cliff with Wilson, ill just twist it with this! 2nd, leatherman's are better!
Apr 15, 2009. 10:30 AMdavid_baines says:
It is amazing what can be done with a pair of pliers and a paperclip! Great tutorial with very clear photos. Thanks.
I came across an optician who came up with a way to make eye glasses using similar techniques.
Apr 4, 2009. 9:35 AMchiao says:
This is the same concept as a machine my father and I used to use for making rope from jute twine. Well done; I'd never thought of shrinking it down to use for wires!
Apr 3, 2009. 4:40 PMBen The Builder says:
I like this idea, I'll probably never use it but it is simple and yet very useful, good job!
Apr 2, 2009. 6:32 AMKD7CAO says:
This is a neat idea for doing multiple wires by hand, for longer wires or for doing stiffer wire, use a cordless drill. Slow speed is always the best.
Aug 11, 2008. 7:42 AMmatrix828 says:
sick swiss army knife! i got smaller version. where did u get it from!?!?!?!
Dec 24, 2007. 1:35 PMledzep567 says:
wow, this is awesome. this can be modified to be a whip finisher for tying flys(as in fly fishing.)
Dec 3, 2007. 8:45 PMzorro3355 says:
i love swiss army!!!
Nov 30, 2007. 11:50 AMLotus14 says:
Very crafty, I like it...you can use the concept and make it out of a number of different bits.
Jul 1, 2007. 1:49 AMgirrrrrrr2 says:
cant you take some sheet metal bend it drill some holes in it and then attach the metal to your table... instead of the straw?...
Jun 8, 2007. 2:58 PMBongmaster says:
that looks kool :) will have to try that :) although that is a drinking straw not a coffee stirrer ;)
Jun 8, 2007. 3:51 PMBongmaster says:
that looks so much like the very same drinking straws i used to make my minikite frames :S I'll take your word for it tho :)
Jun 8, 2007. 4:07 PMBongmaster says:
thnx :) i need to get some larger paperclips i think :S
Jun 6, 2007. 11:04 AMPKM says:
/me seems to remember you are meant to twist wires going along the length, not from the whole length at once. Could you make the hooks into loops in the paperclip so that the wire feeds through them? Would probably be harder than this method though, and I have no idea whether that's actually the correct method for twisting wires- we did it by hand back in the good old days.... of GCSE electronics :P
Jun 6, 2007. 9:44 AMPocketSized says:
Cool Instructable. This is definitely a handy little tool to have laying around.
1-40 of 42next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:CMPalmer
