3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Free Yacht Chapter 4: Outboard Motor Mutilates Foot
Step 3Gear Oil in Bottom End
So I took it home and set about getting it ready. First step, top off the bottom end with oil.
"Some leakage is good, it means the bearings are being lubricated" says the manual. In other words it's likely the bottom end would be empty and need frequent refilling. The manual calls for SAE 140 oil.
I looked everywhere but grocery, drug, and parts stores only have multiviscosity with names like 10w-30. That's runny 10wt. oil that's supposed to lubricate as well as thick 30wt. oil. That's fine for new motors that are designed for it. But old ones are different.
Viscosity is the number of seconds it takes a liquid to drain out the hole in the bottom of a "viscosity cup" and empty it. An old machine is like that. A can of oil with holes in it. I needed straight-weight thick oil so it would stay full longer.
The Society of Automotive Engineers (SAE) Committee of Unctuous Pedants thinks that runny oil is good somehow. They can have it. I finally found the right stuff at One-Stop Autoparts.(510) 653-2821, 6040 San Pablo Ave, Emeryville, CA 94608 Woohoo!
I cleaned the plug threads and added an o-ring to the plug before putting it back in place.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1250
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
