loading
Step 2: Antenna making
The picture is pretty self explanatory. Get a piece of cardboard that is around 1 foot by 1 foot. Get a piece of aluminum foil the size of your cardboard square. Then staple each corner of the foil to the board using staples. If you are like me and don't like going outside or don't have the time to mount the antenna, then hang it in a room somewhere and connect it to a generator. If you have the time and like going outside, put it on a pole at least 10 feet high off the ground. Also, the pole that holds up the antenna has to be made of some insulating material, like a PVC pipe. Refer to the second picture if you need help.
<p>Actually this is <a href="http://batteryrecover.com" rel="nofollow">the best energy generator</a> from batteries</p>
<p>Looks great ! :) Thank you techno guy</p>
<p>You should check the videos from John Richard on how he built the free energy generator it and posted it on his website.</p>
<p>halo i ask pecuse i want put transformator it is from v0.9 to 12v wult work or not pucuse i cray electro makets power no work coil free enegy ind no work put in the coments pelow it seay that it no fake plise anser me if uou can in hire </p>
<p>I had a little trouble understanding what you are asking. I think you're asking if it's possible to add a 0.9 to 12 volt transformer to increase the power output?</p><p>If so, then in theory yes. In practice it probably won't work (at least not very good) because the power generated by these devices is so small that amplifying it would make the current even smaller (and less usable).</p>
<p>Great place to learn how to make it yourself much much cheaper. Just google for 'http://inplix.com' website:)</p>
<p>Hi TechnoG: Wanna ask you if u ever tried to make the Howard johnson full magnet perpetual motor ? it was published on popular mechanics in the sixties, and despite many life demo;s they never let him commercially sell them..</p><p>take a look</p><p>http://3.bp.blogspot.com/-WT4wFuN7_-E/Ts4W9GL4tRI/AAAAAAAAB7Y/WyISqx5E-Mw/s1600/Howard+Johnson+Magnet+Motor+1980.gif</p>
In energy device #5,could i connect mor than one ,so that i can get higher voltage?
<p>In theory. If you try it, I would be interested to see what your results are.</p>
<p>Isnt this just drawing energy from radio waves? Im not discrediting free energy there is just a lot of fakes out there.</p>
<p>yes this more free to me energy free energy is scientifically impossible but theirs lots of ways to get free to me energy. </p>
<p>Ok, I made this a long time ago and didn't know too much about physics at the time.</p><p>Yes, this is probably drawing energy from radio waves (hence the antenna)</p><p>It isn't fake though as it does produce (miniscule amounts of) measureable voltage.</p>
<p>May I suggest using a bridge rectifier <br>maybe a Schottky type or silicon carbide diodes as they may be more <br>stable over wide temperatures. </p><p>I wonder if you used an LC tank circuit fed into a bridge?</p>
<p>Future is here - Free Geen Energy without poison or toxins...http://medelis.se/</p><div><div>I named this MEDELIS BATTERY</div></div>
<p>Tesla was the man never mind Edison never mind Marconi and the rest Nikola Tesla we salute you ! </p><p>Steve 2e0nhr</p>
<p>yes so true</p>
Finally, someone who realizes true genius. I'm with you buddy, what these other guys have done is great, but has NO comparison to the work of Nikola Tesla and some was based off of Tesla's work anyway.
<p>???⚡?</p>
<p>???⚡?</p>
<p>???⚡?</p>
<p>PLEASE PLEASE, Create a video demonstrating how to create this device and how it works. </p>
Hi there <br>thank you.
<p>Hi there</p><p> It is nice to know that the electricity is free .</p><p>so why every one pay for it?</p>
<p>Because most people dont want us to KNOW it's free, and that energy is everywhere. that means no money for the producers</p>
<p>cheers tesla</p>
<p>cheers tesla</p>
<p>dope stuff.got to try it </p>
<p>can you use a higher voltage capacitor for number 5</p>
<p>Okay so I don't know anything about pretty much anything but I would still like to comment. I am a bit disappointed. At first I was excited about your instructable but if it makes less than 1 volt what is it good for?! Please tell us how to build an extremely powerful one. I appreciate you show us the basics here though..</p>
More powerful free energy devices have already been made, these ones are the basic ones. I recommend trying to build an Akula generator if u want a powerful free energy machine. I've seen diagrams (schematic) to build Akula generators up to almost 2kW.
<p>and why diodes are used</p>
<p>can any one plz explain iys working</p>
<p>Hi Kushanks - I'm not the man here, b ut the 1N4148 diodes are not zener diodes. They are silicon diodes (usually referred to as 'small signal' diodes) which require a 0.7 voltage drop from anode to cathode bwfore they will conduct. </p><p>1N34A diodes are made of Germanium and only require 0.25 volts drop across them before they conduct a current. You could use either one in these circuits...</p><p>mk484 :)</p>
Plz... Someone reply fast!<br>I hav to make i for my science project.
can i use IN4148 zener diode for making device #5?
can i use IN41418 zener diode for making device #5
<p>is kapagen free energy is real.....which can make more then 10kw electricity </p>
<p>Yes you can capture electricity from the air but the current is so small it is practically unusable. </p>
<p>Have You ever seen a thunderstorm?</p>
<p>Have you ever combined this with a joule thief?</p>
<p>Ok so I just got back from my local hardware store. Not really sure if I have everything(fingers crossed). Gonna build it later this afternoon and hopefully be able to get it going by tonight. I'll come back and update later tonight with an update and how much electricity I was able to produce for free.</p><p>https://freeenergyflows.wordpress.com/2015/04/24/the-weird-secret-to-free-electricity-the-generator/</p>
<p>I remember doing this in university and never got the chance to explore further... good for you uploading this and crediting Tesla. One of the greatest men who ever lived.</p>
<p>There is a group doing this. Search Atmospheric Electricity Collectors.</p>
<p>You should check this document:<br></p><p>http://www.free-energy-info.co.uk/Chapter7.pdf</p>
<p>you spelled the to wrong its suposed to be &quot;too.&quot;</p>
<p>2 machines power station level engineer validated, 1 for all children to understand attached as photo, on in link for all engineers who already know every bit of this is used exactly this way every day. Higher output than nuclear per ground space, </p><p>The energy race is over</p><p><iframe allowfullscreen="" frameborder="0" height="281" src="//www.youtube.com/embed/0RNuOMuJ57k" width="500"></iframe></p>
<p><iframe allowfullscreen="" frameborder="0" height="281" src="//www.youtube.com/embed/zrU2lnWCpmg" width="500"></iframe></p>
About This Instructable
613,843views
300favorites
License:
Bio: I am a total nerd who works as a software developer, and knows a bit about computer/software technology. Plus I like space and vintage ...
More by techno guy:Using Multisystem on the Second Partition Raspberry Pi 2: Quick n' Easy RCA Boot the Raspberry Pi from USB
Add instructable to:
