3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Free female USB connectors.
This isn't an instructable to actually make a female USB connector, but to get them out of a PS/2 to USB connector (those delivered with about every USB mouse and keyboard)
Some steps might be obvious but I try to include as much tips as possible to make it easier.
Step 1What you need
What you need
You only need a PS/2 to USB connector (the little blocks delivered with every keyboard, mouse and computer).
If you don't have one lying around, try asking any of your friends (especially if they recently bought a new computer, keyboard or mouse). Usually companies or schools will have them lying around so try there also.
You will also need an exacto knife (or similar sharp knife). I find the blade pictured the easiest to use. I also used a sturdier blade later.
22 comments
Jun 26, 2010. 2:57 PMthe_burrito_master says:
Sadly I'm using one of those right now to type this and I wouldn't break it for the world.
Jun 27, 2010. 5:41 PMthe_burrito_master says:
No i do not want to cut it I need it to use my keyboard.
Jun 28, 2010. 10:16 AMthe_burrito_master says:
lol it's ok. I like the ible btw :)
Jun 29, 2010. 8:32 AMRedgerr says:
ahahha yeah, i use one too, saves a USB slot for other stuff ahaha
Jul 6, 2010. 6:27 AMRedgerr says:
ima gamer too, strange that it dosnt work with your stuff... sorry :( waists a usb slot :(
Sep 6, 2010. 7:33 PMwillrandship says:
If it didn't come with it, then it probably won't work. The keyboard has to be designed to handle it properly, in the controller.
Jun 9, 2010. 1:30 AMrick.leasure says:
Got a simple question: There are 4 pins in an USB, right? I would guess two provide data transfer and two provide power. Does anyone know which is power and which is data transfer, as well as which is positive and which is negative?
Jul 6, 2010. 6:33 AMRedgerr says:
sorry it came out jumbled :(
Jul 6, 2010. 6:31 AMRedgerr says:
Red = +5 V White = Data − Green = Data + Black = Ground
Jun 9, 2010. 7:05 AMseverepb says:
if you look closely, you will notice i drew in the colors on the picture. where each color line is, that represents the metal clip/pin................................ red is pos............ black is ground................... white (blue in the drawing) is data+........................ green is data- hope this helps..
Jun 8, 2010. 9:47 AMMRedmon says:
Not free but I needed some female USB connectors in a hurry and found them for 2/$1 at Dollar Tree in a 12V to Dual USB charger. The housing snapped apart and then you can just de-solder the connectors. Next time, I'll have to dig around for some old PS2-USB connectors.
Jun 8, 2010. 6:46 PMDIY Dave says:
great idea. I'll have to check for usb chargers at my local dollar tree.
Jun 8, 2010. 2:42 PMTSC says:
Like the idea I met try it nice!!!!!!!!!!!!!
Jun 8, 2010. 6:26 AMJayefuu says:
I was about to buy some, so thanks! :D
Jun 8, 2010. 6:33 AMJayefuu says:
I made this! I found that my exacto wasn't man enough for the job so I switched to a nice sturdy Stanley knife. Feel free to use the image if you want to :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Ganoderma
