3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
FreeNAS as a Print Server
Step 8LPRng Configuration: 3 of 3 - lpd.conf
lpd.conf (location: /usr/local/etc/lpd.perms) should also be fine as the default. Things to double check for:
# Purpose: always print banner, ignore lpr -h option
# default ab@ (FLAG off)
# Purpose: query accounting server when connected
# default achk@ (FLAG off)
# Purpose: accounting at end (see also af, la, ar, as)
# default ae=jobend $H $n $P $k $b $t (STRING)
# Purpose: name of accounting file (see also la, ar)
# default af=acct (STRING)
# Purpose: use long job number (0 - 999999) when a job is submitted
# default longnumber@ (FLAG off)
Longnumber
1 comment
Feb 2, 2010. 1:01 AMBillMarcoLarson says:
In step 8 all of the lines that you suggest should be double checked  start  with # [excepting the final line, "Longnumber" ] which I assume means they should be commented out.   I might have expected to be checking for lines with the # removed rather than the reverse.
I would like to confirm that what I should be doing is ensuring the presence of these lines with the # included.
Also: I am connecting  my HP Laser Jet 4L via a parallel port on my Freenas server.   I have been attempting to set up printing from an Ubuntu Linux Host, using the LPD option and there is some evidence that the parallel printer is recognised as jobs are being sent "successfully" but so far no actual output!  Do I need to purchase a USB conversion cable to make this work?
Thank you for all your hard work and forbearance!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Tau_Zero(Napkin Diagrams)
Twitter: @Tau_Zero
