3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
FreeNAS as a Print Server
Step 9Start Things and Set Permissions When Printer Connects
We're going to want to start up the proper LPRng processes when a printer is connected. Type:
"nano /usr/local/etc/devd/devd.conf"
Add to the file:
# start action when USB printer ulpt0 is plugged in
# wait 3 second and then start the spooler daemon
attach 100 {
device-name "ulpt0";
action "sleep 3; lpd;
checkpc -f;
chown 0:0 /dev/ulpt0;
chmod 666 /dev/ulpt0;
echo 'o5L25fgfab' > /dev/speaker;";
This watches for the printer to be plugged in, waits a few seconds, and starts the LPD process. Once that's going it fixes any missing files or permissions with checkpc -f. It then sets proper ownership and permissions on the device and plays a little sound.
8 comments
Jun 25, 2010. 11:07 AMmebkopcznski says:
Even puting the commands in this file /etc/devd.conf (because version 7.1 doesn't have the one informed in instructions), i don't get printer working after reboot. I'm looking for a place where I can put this command. Any ideia?
Feb 22, 2010. 9:40 PMpeephuhpeep says:
Thanks for the nice instruction here! (and thanks to sgrizzi as well as the original author!)
I got a problem that keeps coming back: the file permissions of the /dev/ultp0 keep changing when a printer is plugged out. This we all know that happens..
But I changed the devd.conf file (resided in /etc/devd.etc and also put it in /usr/local/etc/devd/devd.conf).
This is how it looks like:
# This example calls a script when the AC state changes, passing the
# notify value as the first argument. If the state is 0x00, it might
# call some sysctls to implement economy mode. If 0x01, it might set
# the mode to performance.
notify 10 {
match "system" "ACPI";
match "subsystem" "ACAD";
action "/etc/acpi_ac $notify";
attach 100 {
checkpc -f;
END OF FILE HERE
So this should work? But it doesn't? What could be wrong here?
Apr 13, 2010. 8:51 AMbboudewijns says:
I have exactly the same problem. If i chmod and chown manually the printer is working fine, but the devd.conf is not loaded at boot indeed. I dont get it. Dont here the sound as wel...
Any help would be appriciated!
Thanks
Jan 28, 2010. 12:42 PMnadhs says:
 Well I don't have this file or directory under /usr/local/etc/
Jan 29, 2010. 7:33 AMnadhs says:
 Please advise what I need to do in this case ?
Feb 3, 2010. 9:02 PMnadhs says:
verison - 0.7.1 shere (revision4944)
built on - Tue Dec 15 20:12:44UTC 2009
OS Version -  FreeBSD 7.2 Release-p5 revision(199506)
platform - i386 full on Intel(R) Pentium(R) 4 CPU 2.93GHz
please advice
Feb 12, 2010. 11:37 PMzhg says:
look for the file under /etc/devd.conf
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Tau_Zero(Napkin Diagrams)
Twitter: @Tau_Zero
