3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Freestanding Whiteboard
There are a bunch of really nice DIY whiteboard designs on Instructables, and I thought a nice compliment to them would be a simple, inexpensive, freestanding whiteboard that could be made with readily-available materials. In particular for home-schoolers, small studios or workshops it is great. In fact, a group of scouts or other builders could make a whole bunch for a deserving school, club or group in a weekend using little money.
This unit can be made in an afternoon from stuff that you can find at any big-box home improvement store (I got everything from my local Home Depot) for less than 50$US. It can be much less if you work with what you already have, like I did. Note that the dimensions are easily modified from what I present- it is a very flexible and forgiving project. If you want to keep the costs to the absolute minimum, I would suggest that you stick to a board 4 feet wide by 3 feet high. That way you only need one sheet of white showerboard and a half-board of the plywood. Otherwise, the sky is the limit for materials! Note that the board shown here was 5 feet wide by 3 feet high, which gave me a nice big working space. Note also that I made it so you can use both sides. This makes is a nice room divider, too. If you were going to move it around a lot, I would add casters- it is pretty heavy when built.
Step 1Planning and materials.
You will need to first decide how large you want your whiteboard to be. For the purpose of this instructable, I will focus on the size that I built, but all the dimensions are flexible. Take a look at the drawings and the measured SketchUp file attached below for the details. You will need the following materials:
Two 4 x 5 foot sheets of white tileboard
One 4 x 5 foot sheet of 5/8inch plywood (I used 3/5" MDF, because I had it around, but it is heavy!)
Four 8 foot long 2x4 inch studs (you will cut this into 4 6-foot lengths, two 2-foot lengths and (optionally) four 1-foot lengths cut at 45% angles)
Four 4.5 inch long, 3/8inch bolts (The length of the bolts will depend on what you use for the center of the boards.)
Four 3/8inch nuts (if you are careful in your measurements, you might be able to get away with acorn nuts, but getting that to work is tricky, even though it does look nice!)
Eight 3/8inch washers
Eight 1/4inch lag bolts (I actually used some little furniture assembly threaded inserts like this to make it easy to take apart, but I couldn't find them at Hope Depot, so you can use lag bolts instead.)
(optionally, 16 2.5inch drywall screws)
You will also need some basic hand tools:
A drill. Make sure that it is big enough to work with the large-sized bits that are used in the project. A good electric drill will probably work fine.
Drill bits: At minimum, you will need a 3/8 inch drill bit, 1 1/8 inch bit, and (depending on how you attach the feet) a 1/4 inch bit. You will also need a means to countersink the fasteners on the feet- I used a 1/2 inch spade bit, but you can use a Forstner bit or a countersink bit if you have one - I don't.
A pair of wrenches in the appropriate sizes. I used a ratchet set and an adjustable crescent wrench.
Measuring tools. At minimum, a measuring tape and a steel rule. A framing square or something similar in order to make sure that cuts are square.
Saw(s): I did all the cutting with a circular saw, using a crosscut blade for the 2x4s and a composite blade for the rest. If you are not cool (as I am not) an don't have a table saw, you can also use some straight steel angle-iron and clamps to provide a guide for your saw.
You will need a screwdriver to match any screws you choose to use. I needed a regular philips one for the drywall screws that I used.
A couple of clamps, preferably ones with soft non-marring jaws. I like the ratchet-action bar clamps from sears.
I also used a couple of sawhorses that I borrowed from a friend (hi, Pete!) in order to make it easier to do all the cuts. The MDF that I used as the center of the board made a dandy table before I cut it, too...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:blackrazor
I have always loved the interface between the machine-like aspect of living things, and an increasing tendency for machines to act in a life-like way. As a result, I have been involved in computation...
more »
