Introduction: French Cleated Shelves
Picture of French Cleated Shelves
www.5MinuteLearn.com
I should start by saying, we live in a cozy sized home and storage is a premium. My wife and I have wanted to build some shelves to keep all of our family games on – so that we can reclaim the space for a pantry. I have always liked the idea of French Cleats as it allows me an amount of versatility. What I especially like is I can add and take shelves away as needed.
Step 1: Cut to Size
Picture of Cut to Size
I started by cutting down some pre-primed pine I bought at Home Depot. I chose both 6 and 8-inch 3/4 stock. The pictures only shows me making some 8-inch boxes, but the steps apply to any size you wish to make. I made 12 x 12 and 18 x 24 inch boxes that you’ll see here. The cleats are made out of some 4-inch pine as well as the bottom rail spacer.
The cuts were:
8-inch pine
2 @ 12"
2 @ 10.5"
2 @ 18"
2 @ 22.5"
Cleat and Spacer
1 each @ 12"
1 each @ 18'
Step 2: Cleats
Picture of Cleats
Make the cleats by setting your table saw to 45 degrees and ripping the 4" stock in half.
Step 3: Sanding
Picture of Sanding
I sanded all the pieces a bit to knock down some of the primer and other imperfections.
Step 4: Assemble
Picture of Assemble
I then glued and pinned the pieces together using some 18 gauge brads. The whole point of the cleat system is to have two lengths cut at 45-degree angles to lock the shelf into place against the wall. The small piece at the bottom of the box is a spacer for keeping it flat against the wall.
Step 5: Sanding the Joints
Picture of Sanding the Joints
I then sanded the boxes down again, smoothing out the joints. Not shown in the tutorial is I filled the nail holes, sanded again and then painted the boxes and the cleats. I used three different colors of paint, which matched the palette of our living room.
Step 6: Mount the Cleats
Picture of Mount the Cleats
I found the wall studs with a stud finder and pre drilled my cleats. I used 3-inch screws for mounting the cleats and leveled them as I went.
Step 7: Add the Boxes
Picture of Add the Boxes
I then placed the shelves as desired onto the cleat. My intention is to keep the shelves spaced apart, but the cleated system allows for you to place all the boxes/shelves side by side so that you get a shelf and then additional storage below inside the box.
*** Not shown is, I made a 36 x 18 and a 24 x 24 inch box for another part of the house. I also made a cleat to go across the middle of the 24 x 24 inch box to hang a 12 x 12 box inside of it – for kind of a shadow box effect.
Step 8: Enjoy
Picture of Enjoy
Thanks for checking out my Instructable!
Lovetra (author)2016-11-23
The pictures give some idea as to the weight these will handle. The boxes hung are heavy in themselves and paper ends up weighing a lot. It amazes me how strong these things are. How deep do you suppose a shelf could still be practical?
skylerskinner (author)2016-05-25
Haha, did you watch tabletop too? Because that also made me buy Zombie Dice, Tsuro and Forbidden Island.
Yes, I have to admit I am a big fan of Table Top. Most (if not all) the games I have bought recently, have come from watching the series.
ulma doctor (author)2016-01-10
very cool idea!
Uncle Kudzu (author)2015-10-27
Beautiful! Seems very practical, too.
tomatoskins (author)2015-10-26
This is so cool! I love French Cleats! They are really strong and quite simple!
5MinuteLearn (author)tomatoskins2015-10-26
Thanks for noticing! I wish I had done this a lot earlier!
About This Instructable
3,419views
108favorites
License:
More by 5MinuteLearn:Split Cedar LED Wall LampMonster WreathsFrench Cleated Shelves
Add instructable to:
