3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
French Fries Recipe
French Fries Recipe
Easy fast french fries made from scratch! These are the best fries you will ever have.
Season them to your taste - salt & pepper? Curry? Cayenne and chili powder. Fresh garlic. Grated parmesan. Spicy mustard. No matter how you trick out these chips, they're guaranteed delicious.
Step 1Materials
Materials
  • Potatoes - 1 per person is more than enough!
  • 1qt/ltr cooking oil - peanut oil is best
  • Seasonings - I just used salt, but this is where you can get creative!
  • Knife for cutting
  • Colander for rinsing
  • Pot for frying
82 comments
1-40 of 82next »
Mar 23, 2009. 1:51 PMkarlmnz says:
Hmmmm, can't wait to try it! What does the soaking/refrigerate in ice-water do? And what is better 30mins or 2 days soak?
Apr 2, 2009. 1:16 PMSinAmos says:
Peanut oil is the best. This must be emphasized.:)
Jun 30, 2009. 2:45 PMbgmiller says:
Soaking them in water also helps removes some of the starch which also helps them crisp better (Supposedly). Here is some more info:
Potatoes and Ice Water
Many recipes for French Fries (as well as other potato recipes) recommend soaking the potatoes in cold water for thirty minutes. The rationale is that some of the starch is leached away and helps the texture of the potato, but this simply doesn't make any sense. The starch on the outside edges of the cut potatoes may wash away, but significant starch or nutrients are not likely to be changed. There may be some slight change in the moisture content of the potato, however.
It is more likely that the inside of the chilled potato takes longer to cook. Consequently, the outside will be crispy and the inside soft and moist. This recipe was tested both ways (with and without soaking the cut potatoes in ice water) and the soaked potatoes were lighter and fluffier on the inside and crispier on the outside. (From: http://www.drgourmet.com/recipes/extras/frenchfries.shtml)
Dec 28, 2009. 6:27 AMmacbutnot says:
bgmiller:  about the starch, if you try this out, you'll actually see it happening.  I used to work in a restaurant which made around 800lbs (weight of the potatoes, not the finished product) of everyday by almost exactly this recipe.
We'd soak the potatoes whole for an hour or so and then slice them into fries and put them in new water where they'd rest for about 3 hours in a cool cellar.  After they were done here, we'd take them up to our big ol' sinks and rinse them off for a good 5 minutes.  Even in the last step, you can see the starch foaming in the water!
Aside from the soak/cut/soak/rinse method we used, the only major difference was that we only used suet (beef fat) for frying, and the old guys who had been running the place since they were teenagers insisted that the fries be cool before they were fried a second time.
Our fries were good enough to be rated best in the city for something like 10 years in a row by the readers of our local entertainment magazine.  People line up around the block, killing off their whole lunch hours to get at these things, even in the dead of winter!
Good job, schoochmaroo!
Feb 10, 2010. 8:06 AMWILL62 says:
Bags of FF you get at the store (Ore Idas) have already had the first "FRY" at the plant before they were packaged....... so I put my FFs on a cookie sheet after the 1st fry at 325 and put them in the freezer til frosty then I deep fry a 2nd time at 360 makes for super crunchers....be careful with the hot grease and frozen anything it may bubble up and burn ya....
Apr 28, 2012. 10:45 AMvincent7520 says:
Perfect.
Double fry is the secret. That's how my grand mother cooked them and I can tell you for sure that it's not a trick from bad memory as this was the only thing that she cooked right (she was such a terrible cook ! …)
Love them ! …
Feb 21, 2012. 12:45 PMTheCritic says:
Nice job, I also liked the comment about the beef fat. A lot of steak house restaurants use the same method using beef fat in the fryer. Gives them a GREAT taste. The only thing I do different is to par boil the fries till outside starts to get rough keeping the inside uncooked then freeze for twenty minutes to remove excess moisture from the potato. It makes for a much more crispy fry and it STAYS crispy longer. Then I do your Double fry method but the second temp I use is 380 degrees. For a really crispy ext on the fry, Try corn starch lightly sprinkled on the outside of the fry. The science behind this is that starch in the potato moves to the outside and that is what makes for the crunchy outer layer. By soaking the potatoes, it allows moisture absorbed by the potatoes to push MORE starch to the outside of the potato, by adding starch to the exterior makes for the crispiest fries. BK uses this method in there restaurants now. Nice instructable.
Feb 21, 2012. 12:39 PMTheCritic says:
Nice job, I also liked the comment about the beef fat. A lot of steak house restaurants use the same method using beef fat in the fryer. Gives them a GREAT taste. The only thing I do different is to par boil the fries till outside starts to get rough keeping the inside uncooked then freeze for twenty minutes to remove excess moisture from the potato. It makes for a much more crispy fry and it STAYS crispy longer. Then I do your Double fry method but the second temp I use is 380 degrees. Nice instructable.
Mar 23, 2011. 4:03 AMkarancheema2010 says:
This is very tasty
Feb 28, 2011. 8:34 PMbroman-1 says:
Potatoes in water is for nothing other than keeping them from oxidizing (browning.) Potatoes do this shockingly fast, so basically, as you're cutting your potatoes, you store them in cold water to keep them from getting black and gross (which can happen in about 4 minutes exposed to open air.) Nothing more, doesn't affect cooking, doesn't change starch content.
Aug 6, 2010. 6:21 PMJunkBot Bob says:
Hm, that's funny, my other comment accusing scoochmaroo of plagiarizing Emeril's recipe is gone. Why would that be moderators? Please, tell me why you would pull my comment and not this unattributed and blatantly plagiarized instructable? Does copyright mean nothing to you?
Oct 31, 2010. 9:47 AMFoaly7 says:
You must have not read this instructable at all, or you wouldn't have missed the qualifier for plagiarism that is not there. She didn't claim that she came up with the recipe, but that she uses the recipe. I know for a fact that I have had many an idea myself that somebody else has already had, but I did not know at the time. You shouldn't accuse someone of something that they clearly haven't done without knowing the whole facts.
Aug 6, 2010. 6:55 PMNachoMahma says:
.  Was the comment pulled or did it never appear? It may have gotten hung up in the filters. If that's the case, it may be Monday before it shows up.
.  From what I can tell, Robot does take copyright/plagiarism seriously.
Aug 7, 2010. 7:17 AMGoodhart says:
Indeed, but I "think" the name comes from the "french cut" of the potato, just as there are Frenched string beans (after the way they are cut).
Mar 24, 2009. 11:22 AMDoctor What says:
Tasty.
Mar 28, 2009. 9:35 AMneverbeenkissed says:
why are they called french
Aug 7, 2010. 7:13 AMGoodhart says:
It is similar to the "French cut" of certain string beans, I think
Aug 6, 2010. 9:43 PMthegreat58 says:
Well If scoochmaroo plagerized Emeril then he plagerized me, I was making french fries that way before Emeril Lagasse was in three cornered pants. I make my fries now-a-days by boiling the potatoes for about 5 min in salted water, drain put in the fridge till dead cold, chip then fry, crisp on the outside, soft and fluffy on the inside. Unofficial instructable.
Aug 6, 2010. 11:29 PMsteveastrouk says:
+1 I like that way too. We also cook them in low (<80C) oil, chill and fry.
Jul 15, 2010. 9:05 AMWILL62 says:
the British put "MALT VINEGAR" on their frys er chips, its a nice change but I am a Heinz catsup man.....
Apr 17, 2010. 1:51 PMalbylovesscience says:
awesome pics !  and tasty food!
Apr 5, 2010. 2:53 PMTaigatoradora says:
I just washed them, I didnt feel like waiting I'm hungry
Mar 3, 2010. 8:37 PMElvenChild says:
 Heres what I do I take a few potatoes scrub em down good. dice them up wash em again and put em in the frier for 5-7 minutes.
Jun 30, 2009. 10:26 AMtrf says:
i usualy do them in a deep frier at 350 degrees
Feb 21, 2010. 6:47 PMDr.Bang says:
 But this is good because most people don't exactly have deep fryers easily accessible. Great instructable! love the crisp taste of good fries :P
Aug 18, 2009. 1:31 PMlilpepsikraker says:
i love crunchy almost concrete fries. will try this sometime, bookmarked! 5*
Jun 29, 2009. 9:29 AMknexsuperbuilderfreak says:
Refrigerate at least 30 minutes and up to 2 days. i dont get this part
Jun 20, 2009. 4:35 PMReCreate says:
You should try oven baking them...Its probably healthier because it has less fat/grease/oil...and they end up almost perfect...you heat up the oven to like 340 degrees and you put them on a cookie sheet(metal) and they are good... Good i'ble, rated.
Jun 13, 2009. 7:55 AMArshad115 says:
i havent tried the refrigerating and soaking thing....will give it a try soon!!...
May 14, 2009. 7:39 AMdriesyo says:
French Fries are bad realy bad the fries from belgium ar way much better
Jun 2, 2009. 6:31 PMshadow760 says:
yah well wer not in belgum so nu
Jun 1, 2009. 1:11 PMWambotrot says:
So?
May 31, 2009. 7:22 AMDoc Opa says:
Just read Cook's Illustrated's article on cooking French fries starting with cold oil. I'm definitely going try the cold oil technique. Looks a lot easier and the fries absorbed less oil!
http://tiny.pl/37r8
May 15, 2009. 4:28 PMal145 says:
you have big potatoes i have small ones
Apr 2, 2009. 7:44 PMkitze says:
Why do you need to refridgerate the fries before cooking?
1-40 of 82next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
3805
Author:scoochmaroo(Click here for more!)
Editor of the Food and Living channels, I believe making things is fundamental to being human! Follow me to see what makes me human.
