Friction Bike - Homelite 26cc Motor
9,240
116
5
Published
Introduction: Friction Bike - Homelite 26cc Motor
first off determine your motor. I got mine from a homelite 26cc weed whipper. simply take the outer casing off the motor to begin.
Step 1: Drive Shaft
I used an old bike axel to attach the bike peg to the motor. initially I squared the bolt to fit into the socket but later you'll realize why that's a bad idea.
Step 2: Mounting the Motor
I used angle iron and 1/4" bolts to attach the motor to the bike. NO WELDING! I did have to grind a portion of the angle iron to account for the flywheel. I used the screws from the casing to attach the angle iron to the motor base.
Step 3: Mistakes
the bike axel I used broke. but it helped because I saw a threaded bolt underneath the socket.
Step 4: Fixing Mistakes
I was able to take the bike peg and drill out the thread in it because it had to fit over the previous shaft. I then used a stop nut and washer to hold the peg. the stop nut is critical. for added assurance I added to screws between the flywheel fins to insure the peg wouldn't spin while riding.
Step 5: Finish
I used an old coat hanger to control the throttle. (not permanent.) and I use the brakes to stall out the motor when I'm done riding.
Step 6:
this was my first instructable. if I wasn't clear enough or you have more questions please comment and I will try to respond.
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    5 Comments
    Your project is really good. many grass engines sleeping rusty waiting to be useful...good project. I suggest you install the engine down with one small gear engaged direct to chain. this will give better power utilization and saves the tire from wear.
    Wow! That's pretty good
    That was quite good! Another request for videos as well. ;)
    Nice job on your first Instructable. Do you have any videos of the motor working?
