loading
Step 2: Handy Tools to Have on Hand
Some tools that are great to have - but not really required:  A pressure/casting vessel (a large paint pot in this case purchased off eBay), a vacuum pump capable of a very high level of vacuum (eBay again), an air compressor (to pressurize the casting chamber), a vacuum chamber for use in de-gassing silicone (mine is a Nalgene 5305-1212), and a cheap toaster oven (that you don't use for food) for heating up clay and post-curing silicone molds (not necessary - just speeds up the process).
So, why de-gas your silicone and pressure cast your resin?  Pressure casting yields much better results than "gravity casting" or casting at atmospheric pressure.  Molds that have fine details will almost certainly end up with bubbles in the castings - either from air entrapment, surface tension issues, or moisture in the mold (resin+water=foam).  Casting under pressure (80PSI in my case) basically "crushes" the bubbles down to almost nothing - or to a size much much smaller than they would have been without it.  Of course, this same phenomenon (crushing the bubbles) ALSO works on your molds - so if your mold has bubbles below the inner contact surface, those bubbles will be "crushed" and will produce bumps and bulges in the surface of your casting - so - if you want to pressure cast your resin, you need to have bubble-free molds to go with it.
If you aren't going to pressure-cast parts, you can skip the compressor and pressure pot.  If you are going to use a mother-mold system, or, some of the thin-viscosity mold-making silicones (less durable but easier to work with) then you can forgo the vacuum chamber and vacuum pump.  What you choose really depends on your end goal and what you're willing to put up with in exchange for your time and money (Isn't that the case with just about everything?)
<p>If the silicone is degassed you should not have this issue with the resin cast parts under pressure</p>
<p>Agreed. The ideal, IMO, is a properly de-gassed silicone mold, and pressure cast resin to almost completely eliminate bubbles in the casting. My purpose in this step was to show what can happen if you don't properly de-gas your silicone, and you pressure cast in that mold. It was also to show how effective pressure casting is at eliminating bubbles in the casting.</p>
<p>That's one beautiful piece of art! Looks amazing. She's bad-ass! :) Thanks for sharing the steps to your talent.</p>
<p>This instructable is a tour de force in creative and scientific mastery. I am stunned at your talent and incredible attention to detail.</p><p>...in '80s-speak: You totally rock, dude!</p><p>Thanks so much for taking the time to document and post this incredible (and awesomely successful) project. I am really, really impressed!</p><p>Cheers! </p>
Thanks, Syntegrator - it was a challenging project, but I learned a lot (which is the whole point). I'm glad you liked it :)
<p>woah you're a master!</p>
<p>I'd like to thank you for your detailed description of finishing your 3D printed figurine. For me, one of the best tips was using putty and Duplicolor filler primer. This made a huge difference in the final surface finish. Much appreciated and awesome job!</p><p>Gunter</p>
Hi Marko, <br> <br>The service I used for the &quot;print&quot; was 3DArtToPart.com - but I don't know if they're still running(?). The print, at the time, cost about $250 which was far more affordable than the $7K-$10K quotes I was getting from places that provided a better surface finish. Prices have come down and quality has gone up since that time - so you'll probably have to do a little searching around. <br> <br>There are a number of places that will print a model for you, but they seem to come and go. Protodemon.com was a place that specialized in outstanding surface quality and detail - but they seem to have disappeared. I would search for 3D Printing Services, or Rapid Prototyping Services and just check around for the best bang for the buck. A good place to ask around would be the zBrush.com forums - those guys do a lot 3D printing. Good luck! :)
HI - Awesome instructable! If I may ask, where did you have the object 3D printed and how expensive was it? I would like to follow your instructable with a smaller, less complicated 3D character and I am new to the 3D printing world. <br> <br>Thanks again for this great instructable! --Marko
Nice ! Thank you
wooow you are friking awesome!
thank you for taking the time to document this great, instructable - i learned a lot from your work, and will read this several times - Great mold making and beautifull character
My god, you have left me breathless throughout all the instructive reading. The quality that you has developed to generate all the steps to creating a perfect (why not say) molds and models, makes it can receive more than one award. To say that and from now this instructable became part of my book training (I'm not writing a book, just learning this), my sincere congratulations on the entire process of manufacturing parts, and this spectacular steep-by-steep instructive. <br>By the way my brother wants to know what is the approximate cost of the figure, in materials and paint-work, figuratively &quot;comparing it&quot; with other models that may be for sale, warcraft, mass effect, etc. ..
Thank you for the kind words :) It was a lot of work, but I learned a lot in the process. <br> <br>As far as cost of materials, there's probably somewhere around $80 in resin and another $45 or so in paint depending on what brands and colors you buy. I don't know how that compares to some of the other models for sale - but I'm assuming this would be quite a bit more since it's not mass produced. <br> <br>Thanks again - I'm glad you enjoyed the Instructable :)
Wow, this is an amazing project. The final outcome is incredible. <br>This just goes to show the large amount of skill and hard work needed to create this piece of art. Your painting skills really make this thing &quot;pop&quot;. <br>I really enjoy reading your presentation.
Where did you get your vacuum degassing machine? Never seen one like that!
I got it off eBay ;) It's a <u>Welch Chemstar 1402N Vacuum Pump</u>. It can actually &quot;boil&quot; water!
Thanks for the info!! Great instructable :) Is the chamber itself made by Chemstar too?!
You're welcome - I'm glad you found it useful :)<br> <br> The vacuum chamber is made by Nalgene and is similar to this one: <a href="http://www.amazon.com/Nalge-5305-0910-Nalgene-Vacuum-Chamber/dp/B001424O3C/ref=sr_1_12?s=industrial&ie=UTF8&qid=1347399752&sr=1-12&keywords=nalgene+vacuum+chamber" rel="nofollow">Vacuum Chamber</a> .&nbsp; I was a bit disappointed with the gaskets that came with it - the rubber just couldn't stand up to the vacuum - so I poured some spare mold silicone into the &quot;groove&quot; around the base (with the chamber removed of course) and it formed a really nice gasket.
Superb instructable and great work! Loved it all. Many thanks for sharing. Paul
Anyone ever notice how all of the female characters have un-natural enlargements (top-heavy)?
I'm a little more concerned with what's going on with her back. XD Spines don't work that way!
One thing I've learned over time is that as soon as you think there nobody that looks a particular way or that the human body can't do some particular thing - there's always someone out there that is going to burst that particular bubble ;) <br><br>You might want to check out The Ross Sisters &quot;Solid Potato Salad&quot; on YouTube - http://www.youtube.com/watch?v=d1J3NLNWAPU - they bend in ways that make you say &quot;ouch&quot; - lol
Hmmmm - That's not really correct. There are a lot of characters that aren't &quot;top heavy&quot; but they may not be the ones you notice. A lot of the design depends on the genre the character fits into (Fantasy, Anime, Manga, Realistic, etc). Being of the &quot;Fantasy Art&quot; genre, this character is very &quot;hippy&quot; and although her proportions are pretty extreme (in &quot;real life&quot; she'd be over 7 feet tall without the wings) they aren't out of balance IMO. <br><br>Everyone is entitled to their opinions, though - it's what gives us the variety we see in life.
That is an GREAT work! Do you sell it? <br />Regards.
Thanks! I've sold a handful of kits, but never really put it into full-scale production. It's difficult to justify the amount of time it takes to produce the kit (about 8 hours per) vs. what I can reasonably charge for one. If you're interested, you can PM me - I may have enough parts around to put together a full kit ;)
Wow, what a brilliant instructable. Really appreciate how much work you put into this. Thanks so much for sharing.
Nice job!! I love the intricate details involved.
I have to say that this is THE best documented Instructable I have ever seen. Profusely photographed, exceedingly well written and an absolute joy to read. You did a masterful job in taking it from CG to 3D. It is obvious there is a ton of work and multiple tons of attention to detail. I humbly subscribe in the hope of seeing more from you...
Thank you :) I hope to earn that compliment :)
What program is that??
The original model was built in Hash's Animation:Master. The model was exported as an OBJ then imported into Softimage for cleanup.
amazing job really fasnited about cleaning up a 3d print
why did you choose person, who is it??
I'm not totally sure what you're asking - but - it's a character I modeled for fun, based on a fantasy art painting.
ok i thought its a carictor from a game
Nice work!
Thanks! It was a *lot* of work ;)
About This Instructable
79,763views
278favorites
License:
Bio: I am a perpetual student, researcher, and hopelessly dedicated skill collector. I hope that you can find something inspiring or useful in the instructables I ... More »
More by jwilliamsen:Sporterize a Military Surplus Rifle Restore an Old Vise Make A Barbarian's Sword
Add instructable to:
