loading
Step 4: Preparing the blank
OK, get out your saw and your log. We're gonna cut all the way through that sucker! If this is your first time attempting bowl turning, don't use an amazingly nice wood. I guarantee that there is a very high chance your bowl will still break. Don't use something like pine since its actually very unpleasant to turn.
Get ready to cut!
Yes, seriously. It's not impossible.
Now, look at your log. Now back at my bowl. Now back at your log.
Now visualize the bowl in the log. You need to cut a chunk of your log that you will be able to turn your bowl from.
One note: it may seem natural to turn a bowl with the endgrain parallel to the axis of rotation. The log is circular, so you just crosscut a piece that is tall enough or the bowl, right? wrong. The grain is not oriented the same way as with spindle turning. You can, but it's much harder to make an endgrain bowl.
Instead, we are going to rip cut down the middle of the log to make a...semicircular prism. The flat face is what you put on the faceplate.
When the bowl is done, the grain will be running through it sideways.
You want to end up with a bowl blank that can fit on your lathe and can fit the size of the bowl you want. Cutting a perfect square will waste the smallest amount of wood. You want to cut down along the grain of the wood a length that's about the same as the diameter of your log.
Once you've cut down far enough, crosscut to release the piece.
I like to use a bright red sharpie to mark the line to cut, and i actually put my log on the lathe and use the tailstock to hold it on place while I'm cutting. Make sure you tie the log to the bed in case it slips.
Use your entire body while cutting, (like hand planing) not just your arm. You'll cut faster and you'll be less sore. If you feel like you need to push too hard to get a decent cut, sharpen the saw. I use an abrasive dremel wheel and lightly touch each tooth.
Once I'm finally done cutting the rough blank, I lay out the biggest circle that will fit on the face. Draw lines corner to corner to find the approximate center, then use a compass and move the center around to find the center of the largest circle.
Now temporarily mount the log on the lathe. Just use a spur center to hold the log on its centerpoint. Spin the log and see if the corners hit the bed of the lathe. If any of them do, mark the corner and cut it off. Once you're done, screw on the faceplate in the center. Make sure you use wood screws and not drywall screws. Drywall screws are brittle and can easily shear off. Also, it might be a good idea to drill pilot holes because the screws can get suck if the wood moves too much. This happened to me once and i had to drill out the screw. It's a good way to ruin a good day.
Now you get to start turning!
<p>Great bowl! I've made a few bowls, and I was envious of how thin your walls were--until one broke! You did a great job of recovering it, though. I need to get my courage up and try that. Nice work!</p><p>I'm sure you're not short on blanks, but if you ever run low, your local dump probably has a place for logs and yard waste. Mine does, and you're allowed to take anything you want, no charge! We have a lot of cedar and hackberry here, and we sometimes get osage orange. You should check it out if you get a chance!</p>
<p>Nice bowl. You know it would be a lot easier to cut the blank into a round at the bandsaw? If you do that then it wouldn't be so out of balance and you can start turning at around 600 revs. Works for me!</p>
Actually, I didn't own a bandsaw when I made this instructables/this bowl. <br>Since then, I've purchased one. It definitely makes cutting the blanks a lot easier! I actually have an excess of blanks now that I haven't had time to turn. Oops!
How beautiful bowls!
Aw, thank you :) The wood is pretty amazing. <br>Muchas gracias. La madera muy brillante tambien.
es*
Very complete instructions about turning, thanks for them. I will try green wood, you convinced me. <br> <br>For food-safe finishing, I use egg white (albumen). When dry, the light hardens it and turns it insoluble. You must do 6 or 7 coats to get a semi-gloss finish. Fine sanding between coats. A coat dries in 2 to 4 hours depending environmental humidity and heat. <br> <br>You can save the albumen 2 or 3 days in a closed jar without problems.
I must say that I don't think I have ever heard of that method. <br>The egg whites never spoil or cloud up? That's really interesting. When I get back home I'll have to try that one. <br>Thanks :)
<a href="https://www.google.com.ar/search?q=egg+albumen+as+varnish&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:es-ES:official&client=firefox-a" rel="nofollow">Here you can find</a> some about the matter.<br> <br> I have some photos, but here in comments the uploader does not work.
About This Instructable
25,617views
87favorites
License:
More by frankenboom:From Blank to Bowl Floating Arm Trebuchet (F2K) (almost) automatic paper recycler
Add instructable to:
