From Nothing to Rockets
1,920
12
Published
Introduction: From Nothing to Rockets
This instrucable will explain how to make rocket candy and the casing
Do not do unsupervised
Do not do around open flame
not responsible for accidents
be safe
modelrocketzone.com
Step 1: Ingredients
Stump remover (KNO3)
- stectacide brand perfered
Corn syrup
sugar
Rust
Step 2: Making Rust
you will need
- a cup     - bleach
- coffee filter     -steel wool
Instruction
Put the coffee filter into the cup first                                                Let it sit over night
then put the steel wool into the cup                                                pull out filter keeing the rust from spilling out
Finally pour bleach into cup                                                            Boil off water
*make sure steelwool is submerged in bleach
Step 3: Making Casing
You will need
-paper       - rod        - glue      - Clay
Instructions
cut paper into strips
*cut width of strip as you desire
glue the entire srtip of paper
wrap around the rod tightly to make casing
close one end with clay and let dry
Step 4: Making Rocket Candy
you will need
- Hot plate      - Spatula       - Sugar
- Stump remover     - Corn syrup     -rust
- water     - beaker/cup
Ratios
- KNO3 60%     - Sugar 30%     -corn syrup 10%     *add 5% rust of the mass of the three ingredients
Ex: 50g sample    KNO3- 30g   Sugar- 15g     corn syrup- 5g      *rust- 2.5g
Instructions
put sugar and KNO3 into cup/beaker
- add water to the mixture until all is dissolved
- grind rust as fine as possible then add to mixture
- set hotplate
-when all water boils off add corn syrup
-turn off heat
-mix together until gel like substance remains
Step 5: Filling Cassing
you will need
- rod     -casing    - rocket candy       -spatula     - clay
Instructions
- use spatula to pick up rocket candy
-scrape into casing
- use rod to compact
-repeat till 1/4 inch of space remains
- fill rest of space with clay
-let cool and dry
Step 6: Finishing Casing
you will need
- casing with rocket candy in it     - Drill
Instructions
- use drill to drill small straight hole into casing
Step 7: Finished
You are ready to launch a Rocket!!!!!
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    • Make it Move Contest
