How to Leather Bind a Paperback
222,670
981
84
Posted
Introduction: How to Leather Bind a Paperback
Vintage Contest
Runner Up in the
Vintage Contest
Glue Contest
Second Prize in the
Glue Contest
Turn an ordinary paperback book into a leather bound masterpiece... without any fancy tools or techniques.
I've spent quite a few hours scouring bookstores, libraries, and the web for the answer to a simple question: how can I put leather on my paperback book? There are plenty of book binding Jedis out there, but I'm not interested in restoring an old manuscript, learning about the history of scrolls and codices, or building my own cutesy journal with expensive hand-made paper and fancy stitches. I just want to take a piece of leather and glue it to my paperback and have it look nice.
Well, I tried the "just glue it" method. Twice. It didn't work so well. After taking apart some old books, gleaning what I could from book-binding manuals at the library, and analyzing what went wrong, I tried a third time. This is a record of my third attempt, which was pretty successful, pretty easy, and, well, pretty cool.
UPDATE: for a slightly different method, check out Leather Binding a Paperback: A New and Improved Guide.
Step 1: Measure
Write down the width, height, and depth of your paperback book. Also, write down the thickness of the leather and cardboard you plan to use.
In my case:
Width = 6"
Height = 9"
Depth = 3/4"
Leather Thickness = 1/16"
Cardboard Thickness = 1/16"
Step 2: Prepare Outer Surface for Gluing
Some paperbacks are shiny. Glue doesn't stick to shiny. Rough the outsides with some sandpaper, steel wool, etc.
Step 3: Obtain Glue, Leather, Cardboard
  1. Glue: I used a $6 bottle of bookbinding PVA from Amazon (here). It feels exactly like Elmer's Glue, but it's supposed to be more flexible and long-lasting. You'd probably be fine with Elmer's, or Mod Podge, since you don't really need flexibility for this project. There are also recipes for "wheat paste", a glue made from flour and water, that is pretty common for bookbinding. I've never tried it.
  2. Leather: I used cow-hide upholstery leather, sold for $10/pound from the scrap bin at Tandy Leather. I got a piece big enough for 6 or 7 books for $13. Any leather will probably be fine, as long as it's flexible. My first two attempts involved thick veggie-tanned leather that I had done some carving on, but it didn't work very well.
  3. Cardboard: I used the backs of several cheap notebooks. I would recommend springing for some stiffer cardboard at a craft store or something, if you have the time/money/energy.
Step 4: Add Headbands (Optional)
What are headbands? They are cool-looking little things right at the top and bottom of the spine.
Do they have a purpose? No. But they look cool, and they're easy to make/fake, so why not?
Fold cloth over cord, glue, then glue to the spine at both ends.
EDIT: kewpiedoll99 was kind enough to point out that FAKE/FAUX headbands (like these) have no practical purpose, but signature bound books often have sewn headbands that increase the structural integrity of the book. Here is a fantastic tutorial she found on sewing headbands on signature bound books:
http://hell2breakfast.wordpress.com/2011/01/09/httpwp-mep10o2h-2w/
Step 5: Cut Cardboard
Cut three pieces of cardboard.
All three should be 1/4" taller than your paperback (height + 1/4"). In my case: 9" + 1/4" = 9-1/4".
Two should be 3/8" less wide than your paperback (width - 3/8"). In my case: 6" - 3/8" = 5-5/8".
One should be as wide as the depth of your paperback, plus two leather thicknesses, plus two cardboard thicknesses (depth + 2*leatherThickness + 2*cardboardThickness). In my case: 3/4" + 2*1/16" + 2*1/16" = 1".
Hopefully the diagram makes this more clear.
Step 6: Align Cardboard With Masking Tape
Use a few pieces of masking tape to align the three cardboard pieces with 1/2" spaces between them. The masking tape is temporary.
If you want to get technical, the space should probably be 1/2" plus the thickness of the leather. If you can measure / hold / tape cardboard that precisely, more power to you.
Step 7: Cut Leather
Cut your leather so that it is overhangs the cardboard by 1/2" on all sides.
Draw the outline of the perfectly centered cardboard on the leather. This will make aligning things easier later on.
Step 8: Glue Leather to Cardboard
Glue the leather to the cardboard, with the tape side up (so you can remove the tape when you're done).
Be careful; PVA dries quickly. Glue one sheet at a time.
A paint brush is helpful for spreading the glue evenly.
Use a weight to press the glued pieces so they dry flat.
Step 9: Cut the Leather Corners
Cut the corners of the leather so they'll fold up evenly. Cutting a nice 45-45-90 triangle off of each corner works well.
I cut a tad too much off on mine, so the leather folds don't quite meet each other. Try to avoid this.
Step 10: Fold and Glue the Leather Edges
Fold up each leather edge and glue it in place.
I found a ruler helpful in getting a nice fold and holding down the edge to stay in place.
Step 11: Add Filler Cardboard (optional for Thin Leather)
Your leather now leaves little lips at the edges of your cardboard. This might be ok if you have very thin leather, but if you don't, you'll want to fill in the gaps with cardboard that is about the same thickness as your leather.
Cut three pieces to fit and glue in place.
Use a weight (as always) to hold everything down as the glue dries.
This is a good time to admire how your book is about to fit into this cover.
Step 12: Glue the Cover to the Paperback
Put a sheet of paper (preferably wax paper) between the front cover and first page of your paperback. Repeat with the back cover and back page. This will keep any glue from getting on your pages.
Glue one cover at a time, making sure that the new leather cover hangs over the edge of the paperback by 1/8" on all sides.
Don't glue the spine or hinge sections (see diagram). If you glue these, the book won't open properly.
When everything is glued, put weights on top of the closed book and let the glue dry for a long time (several hours). Use nice flat boards to avoid putting dents in the leather cover.
Step 13: Laser Engrave (Optional)
Since I designed the original cover for this particular book, I happened to have the graphics files. I was also lucky enough to have access to a laser cutter/engraver. I used these to burn the cover design onto the front and back of the leather cover.
An alternative would be to use a soldering iron to hand-burn your own design, or to paint one, or to just leave the cover blank (you minimalist you).
Step 14: Clean Up and Admire
Use some rubbing alcohol to clean up any stray glue... and you're done.
Thanks for reading!
Thane is my first novel. Check out my website and facebook page to learn more about the book and its sequel (an awesome tale about teenage medieval secret agents), read some of my short stories, and see my food experiments on the way to perfect biscuits, pancakes, hash browns, and (someday) all the other greats.
2 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Microcontroller Contest
  • Science of Cooking
    Science of Cooking
76 Comments
thanks for this ible. do you have an idea of the minimum laser power required for leather engravings? I was wondering if kind of Chinese CNC laser engraver could works.
I think engraving should be easy with just about any laser. I've cut through pretty thick leather using a 45-watt Epilogue.
How can you leather bind a notebook with those ringy things at the side?
I'm not sure... I've never tried it. The best way might be to remove the rings, perfect-bind the pages, then proceed as usual. Another possibility would be to cut two separate pieces of leather and gluing them to the front and back covers (leaving the rings exposed).
Headbands are there to stop you ripping the spine when taking the book off the shelf.
Thanks. I was going to say the same thing.
I have bound books for years. One trick that helps to spread the glue quickly and thin is to use an old credit card. I also wanted to say that the cardboard in bookbinding is called Davie board and is more dense than just cardboard. It may be a bit difficult to come by, but if serious about binding books you may want to find where you can get it. Great instructable. I loved the whole premise. Quick, easy and not too involved.
Great tip. I did a quick search for Davie board and came across this website: might be a good resource. Looks like they sell book binding supplies, allow you to pay through amazon, and even have some nice simple instructions for book making:
http://www.dickblick.com/categories/bookmaking/#materials
Talasonline.com is a great website used by professionals. Everything they supply is archival.
