3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
From Sewing Machine to Scroll Saw, a Christmas tale
Step 3Accommodating the blade
Once you work out where the blade will be moving, we just need to work out how it will remain in tension when the the main 'plunger' pushes down (so it doesn't bend up or break).  We can minimise this problem by setting the blade to cut on the up stroke - although this has problems of its own (more on that later).  There are a few ways one could approach this:
1.  Modify the drive that goes to the bottom and moves the swing arm (see photos) up and down and side to side, so that it just goes up and down (and not side to side) the same distance as the main needle plunger.  This would be a nice but complicated solution because you could have the blade being driven, or pulled, from both sides.  I discounted it as horrendously complicated.
2.  Keep the blade in tension by some direct connection to a bungee or spring on the underside.  Hope that this will work well enough to pull the blade down as it will not be cutting on the down stroke anyway.  The problem here is that the main plunger moves a fair old distance and any directly opposing spring is going to have a hard job being effective over such a range of motion.
3. Similar to 2. but use some extra mechanical advantage to reduce the space requirements and demand for high performance bungee or spring.  In my case, this involved spring loading the long arm that controlled the 'feed dog' (the bit that moves the fabric).
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
97
Author:bongodrummer(Flowering Elbow Website)
BongoDrummer is founder and member of Flowering Elbow. He loves to learn about, invent, and make things, particularly from waste materials.
