3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
From Sewing Machine to Scroll Saw, a Christmas tale
Step 4Saw blade to Feed Dog
No don't try feeding your dog anything metal!  You want to make the sewing machine 'feed dog' leaver easily take and hold a saw blade.
I went about this by making a casting of sorts, from JB Weld.  There are loads of pages out there that that consider this (here is one), so I will not go into too much detail here.
First fill the void in the leaver with epoxy. Then cover a sample of the saw blade with beeswax sot it will not be stuck forever, and set it into the epoxy.  You probably want  to periodically rotate the part to prevent the JB from sagging while drying.  Once dry we can pull out the saw blade, and hay presto, a nice little blade sized holder. Now drill a hole and tread it and we can use a grubscrew tightened against the saw blade to fix it in place.
Now we just need to spring load the leaver to keep the blade in tension - that way it should stay straight and not bend all over the place.  So there would be many different ways to approach this, one could mount a 'push' style spring between the leaver and the machine underside, or as I have you can have a twist style spring mounted on the shaft that supports the leaver.  Either make your own from scratch (here is a good DIY spring method) or, as I did, you could probably modify one of the many springs you took away from other bits of the machine.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
97
Author:bongodrummer(Flowering Elbow Website)
BongoDrummer is founder and member of Flowering Elbow. He loves to learn about, invent, and make things, particularly from waste materials.
