3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to Build Your Pop Diva Her Own Stage
Step 4Securing the Deck
Securing the Deck
  • last photo ←
Make sure you pallet is right side up, in the prior step we had the pallet upside down to create cut lines.
Now that you have two pieces of chipboard sized to match the top of the pallet place BOTH of them on top of the pallet. Square them to the pallet so all of the edges are flush.
Pick one corner to start working from. Using you drill create a pilot hole for the first screw. Drill through both pieces of chipboard and into the pallet. This will help to keep the wood from splitting.
Next, using your drill/ screw gun drive your screw through the pilot hole through both layers of chipboard and into the pallet.
Follow the same steps for each corner your screws should go through to and into the pallet frame boards/ribs.
Now continue the same procedure for each of the three ribs in the pallet. I put one screw through each of the cross planks and down the center of the pallet as well.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:Mr. Rig It
I like to build, create, and invent new things to use in life. Sometimes I like to share them with others, that's why I joined Instructables. :-)
