Step 7Install the Side Trim Pieces
You should have enough material, laminate and chipboard, left over to install on the front and rear of the stage. The side of the stage will only need laminate.
Position the trim on the sides and mark cut lines if necessary. Then cut your panels to fit.
Cut all of your panels before gluing. I recommend cutting your side panels first and then cutting the front and back panels. This way your front and rear panels will overlap the side panels edges. This creates a cleaner look to the stage.
Once you have all of your panels cut then glue them and install the side pieces first and then the front and rear pieces.
NOTE*** You don't have to create a rear panel, since no one is going to see if it up against a wall. However, if it is going to be in the center of a room you may want to install the rear trim anyway.
Add Comment
