3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Front-Wheel-Drive Center-Steer Semi-Recumbent Bicycle
With two donor bikes and some other junk, any tinkerer can build a front-wheel-drive, center-steer, semi-recumbent bicycle. (FWD/CS/SR bike for short.) No welding or brazing required! No special tools required! No power tools required (but they can help).
Inspiration for this project came from the following pages:
The $18 Recumbent Bicycle
Build your own recumbent bike, the camel bike
Cruzbike
Why? Because I wanted a recumbent, but I'm too cheap to buy one, and I'm too lazy to build a traditional one. It may be ugly, but it's the most comfortable bike I've ridden!
Step 1Principles and Tools of the Project
This project was originally undertaken with certain fundamental principles in mind:
1) Buy nothing new if available materials suffice.
2) No torches.
3) No special tools.
The good news is that by following these principles, I purchased nothing expressly for this project, and I saved my MAPP gas for more serious projects. On the other hand, aesthetics and perhaps safety are sub-optimal.
The tools I used:
- pliers
- wrenches
- screwdrivers
- power drill (not necessary, but it prevents tendonitis)
- files
- metal snips
- wood saw
- hacksaw
Obviously, by discarding my principles and using better tools, one can make a much better bike. I dare not suggest that anyone exactly follow my instructions; I offer this Instructable merely to give others some ideas.
46 comments
1-40 of 46next »
Dec 19, 2008. 11:51 AMdjr6789 says:
nerly finished mine just need a seet and to mod the handlebars
Dec 21, 2008. 5:45 AMdjr6789 says:
thanks for the idea ill give it a try
Aug 3, 2011. 12:31 AMm a r i a n o says:
I used your instructions to build my rowing bicycle:
http://www.instructables.com/id/Row-pull-push-bike-la-marianette/
http://lamarianette.blogspot.com/
Thank you for the idea!
Jan 31, 2012. 1:45 PMbobcat1947 says:
Loved it !
Jul 24, 2011. 5:14 PMSIRJAMES09 says:
on the front where that partial tube is sticking up, can you put a light or reflector there?? a light might make it easier to be seen or maybe to see after dark.....
Jul 24, 2011. 5:12 PMSIRJAMES09 says:
for the seat, you could use 1/2" plywood for the base, cover it with CLOSED CELL foam & then cover that with open cell foam: about 1" to 3" of each.
The double layers of foam will remove the bounce, yet, still give you a soft ride for maybe 50 or 60 miles. Just a thought.
Jul 5, 2011. 2:46 AMtonyscott says:
it's a nice idea as a starting point, next I'd paint and make a better chair, congratulations mate.
Aug 11, 2010. 8:43 AMnantachayo says:
cheap but enjoy
Oct 2, 2009. 7:16 PMWoodenbikes says:
Very cool bike! I ought to build one too. Perhaps replacing the sheet metal U shaped piece with a thicker piece of flat stock with a 5/16" hole for the stem expander bolt to pass through. Twist it 90 degrees and have another hole for the Seat clamp binder bolt to pass through. (or more elegantly and stiffer is to find a longer replacement for the seat post and flatten the top of it and drill a hole through which to pass the stem expander bolt.)
Aug 1, 2010. 4:18 PM2 stroke says:
ill weld a post diagonlay from the frame to the sem to stop the wobbly ness
Feb 10, 2010. 7:28 PMgreen_rider says:
brilliant, sennomo...
will try and build a similar one... soon... :-)
how stable and comfortable is the seat? how easy/difficult is navigation, especially in heavy traffic? I live in mumbai, india... and the traffic congestion here has to be seen to be believed! :-) what's your average speed on this recumbent?
ride safe... have fun... :-)
Aug 1, 2010. 4:16 PM2 stroke says:
ill weld on some some foot pegs in case u get uncomfortable and want coast like a regular bike
Aug 1, 2010. 4:13 PM2 stroke says:
is Mumbai in mexico
Aug 2, 2008. 12:55 PMmacdadyabc says:
i made a recumbent bike this way about two months ago. I took a walgreens shopping cart, made a chair out of it , and then put two 10" wheels were the back cart wheels were. Then i welded on a down tube and struts, and the front looked just like yours. It was really hard to make it go fast though.
Aug 4, 2008. 12:30 PMmacdadyabc says:
i dont have it anymore. My dad made me take it too the dump, but just imagine cart chair with down tube and handlebars
Jul 8, 2010. 9:53 PMextremegtafan says:
Wow! You had a similar idea as I did! I had a shopping cart lying around. also a junk bike frame. I rigged it up so that the back of the frame is tied in the storage space under the cart, and the regular seat is on the bike. I couldn't figure any way to get it to pedal, so after pushing it like a scooter (and coasting on hills) I remembered this article. I don't have a bike frame on hand that I want to cut up, though.
Jun 27, 2010. 5:27 PMcheesemanlovesrobots says:
love it mate ill probably do this and put 2 wheels on the back. so its a trike
Apr 15, 2010. 4:30 AMctherien says:
Im Making a three wheeler with a big spoke in the front so it pulls back and the handle bars look bigger all i have to do now is adjust the seat higher and put the gear system on.
Dec 30, 2009. 7:47 AMbob48220 says:
ingenious!
Sep 30, 2009. 10:29 AMBillBiker says:
Ummm only one thing to say...........BRAVVVVVVVVVVVVVVVOOOOO!
May 28, 2009. 7:15 PMjohnsonz says:
mad props! that is pure sweetness.
Apr 4, 2009. 5:44 PMhenryxdam says:
lol pure awesome!
Nov 3, 2008. 6:24 PMfancypenguin845 says:
KEWL!!!!!!!!!!!!!
Sep 22, 2008. 10:07 PMextremegtafan says:
Not to sound mean or anything, but my question is: What's the purpose of a front wheel drive bicycle with a giant seat? What does recumbent mean anyway?
Aug 17, 2008. 2:05 PMdjnupi says:
Nice one, Sennomo, brilliant! I spent some time experimenting with the fork, to bend it forward and backwards, to see differences in stability. not much differences. the peddal/steering interference is one of the things you learn to control. recently at a hpv meeting here in Sweden i rode an M5, expensive back wheel drive recumbent. thought, now this will be easy. wrong. more difficult than my fwd camel (oh yes, i am the guy from the camel bike) dont let it put you down your bike only cost 10 bucks! give it a 2 dollar paintjob and it looks 500. the $1000 bikes are not that much easier to ride. Cool bike! bests, dj
Aug 3, 2008. 4:39 PMhandidad says:
Looks interesting. I had been thinking of building a tandem bike. With this approach it would be simplify the drive, because each paddler could drive their own wheel.
Aug 3, 2008. 1:08 AMdepotdevoid says:
What a great idea! Maybe I've got a use for my daughter's old bicycle now.
1-40 of 46next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:sennomo
