3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Front-Wheel-Drive Center-Steer Semi-Recumbent Bicycle
Step 6Add Handlebars and Seat
The two most crucial remaining parts are the handlebars and the seat.
Although it is possible to steer such a bicycle without handlebars, handlebars are helpful. However, most styles of handlebars would interfere with pedaling. Therefore, you must use either BMX or ape hanger handlebars. The other possibility is to fashion a tall stem, but that may require special hardware, such as a long stem bolt.
The seat is very important for both comfort and stability. A bad seat is almost as bad as no seat. I made a seat from plywood, then upholstered it with packing foam and vinyl. The plywood has a nice springiness to it. You may need to experiment with various seat designs before finding one that works best.
1 comment
Jul 24, 2011. 5:12 PMSIRJAMES09 says:
for the seat, you could use 1/2" plywood for the base, cover it with CLOSED CELL foam & then cover that with open cell foam: about 1" to 3" of each.
The double layers of foam will remove the bounce, yet, still give you a soft ride for maybe 50 or 60 miles. Just a thought.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:sennomo
