3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Front Wheel Drive Recumbent with Underbar Steering
Step 4Step Four: Underbar Steering
I wanted to figure out a way to make the bike steerable with under bar steering. Other bikes I had ridden in the past had a semi-complex mechanism which involved a second 'head tube' with a tie rod up to the fork. I didn't want to incorporate that much complexity into my design so I opted to install a handlebar stem through the bottom of the fork.
Since the fork's inner diameter at the bottom is smaller than at the top I decided to grind/sand/file down the stem itself to reduce it enough to fit. The fit was still very tight and I had to drive it in using heat and a dead blow hammer. Using a 10"x3/8" carriage bolt down though the seat post and fork was used to both marry the front triangle to the rear, but also to securely fasten the stem in place.
I settled on a set of beach cruiser bars (pictured later) which provided sufficient reach and leverage.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:briansrapier
