Front Carrier Bin for Brompton Folding Bicycle
808
Posted in OutsideBikes
Introduction: Front Carrier Bin for Brompton Folding Bicycle
I use a Brompton folding bicycle every day and often need to carry large reasonably heavy things. Brompton make a range of bags which fit to the front of the bike on a special bracket. The bags have a corresponding part, built into a frame in the bags, which locks onto this bracket. The bags are useful, but not always big enough for me.
Initially, I asked Bromton if they would supply me with the plastic part of the bag which slots onto the holder bracket on the bike (I'll call it the holder), but they wouldn't. I wanted to fix this part onto a large plastic bin so I could put the bin on the front of my bike. The only alternative was to buy a bag frame and destroy it for the holder, but they're not cheap and it's a bit wasteful, so I decided to make the holder myself.
Step 1: Making and Fitting the Aluminium Parts for the Holder.
There are two parts which are made from aluminium U profile extrusion. The inside dimensions of the section profile are 12.5*12.5mm. The thickness of the aluminium is about 1.5mm. I think it's quite a common profile and is available from either Homebase or B&Q; in the UK for about 10GBP for a 2m length.
I'm not going to detail the making of these parts particularly. If you're familiar with the Brompton carrier, you'll see how the two parts are mirrors of one another and have had pieces cut off from either end to enable fixing to the bin and that a wedge of the aluminium has been removed from the outward flanges of the bracket parts, so the holder will slide down onto the bracket.
The two parts are fitted to the bin with four M4 countersunk set screws. I did this so I could take them off if there was a problem with the design. You could pop rivet the parts on with rivets sunk in small countersinks in the aluminium.
With either screws or rivets, the heads shouldn't get in the way when you slide the bin onto the bike. If you decide on screws, M3 would be better, i think,. With the M4 screws, I had to grind the lower two heads to be flush with the aluminium, as the amount of countersink in the aluminium was leaving very little material.
It's important that when the bin is fitted that the bottom of it clears the front mudguard or front reflector (I removed my reflector to get more room) and that the top of the bin will clear the handlebar. The bin I have is a Curver one and is 410mm high with the lid on. Just try it against the bike with the bracket on the bike first and mark the height of the bracket roughly on the bin.
To fit the holder parts to the bin, I took the bracket off the bike, gaffer taped the holder parts to it and laid it on the bin in position, making sure it was square to the bin and in the middle of it. Then I marked through the holes with a pen onto the bin for drilling.
The inside dimensions of the profile will fit over the holder bracket, but there's a 1mm gap which needs to be filled up with something. I used some plastic banding from a parcel cut to length and stuck on the aluminium with double sided tape. You can see the yellow pack banding in the photographs.
The Brompton carrier frames have a recess where the locking catch fits into the bracket. I have not replicated this on my holder parts as gravity will hold the bin in place adequately and having to reach for a catch to release a bin would be awkward anyway.
Step 2: Choosing a Bin.
The bin I chose has a snap fitting lid and is 410mm tall. It's narrower than the handlebar and is less deep front to back than wide. It was about 7GBP from Homebase.
Note, that my bin wasn't stiff enough and wobbled rather a lot when riding. I ended up stiffening it on the inside with more extrusion and a strip of plywood. See image.
    • Outdoor Fitness Challenge
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    2 Comments
    This project looks awesome but there isn't enough documentation of you actually making it to be a full Instructable. There are two things which you could do. 1) If you happen to have images of you making your project you can create some more steps, add those additional photos into your Instructable and then republish your Instructable. 2) If you don't have any more pictures of you working on your project, that's ok too. That just means that your project is better suited to be submitted as a slideshow. Your images are already in your library, and you can use the same text that you have already written for your Instructable so it should only take a few minutes to create your slideshow and show the world what you made! Thanks for your submission and let me know if you have any questions along the way.
    I'll have a go when I get some time. Thanks.
