Introduction: Frozen Chocolate Bananas
One of my favorite carnival/fair treats is the frozen chocolate banana, however I feel that the price at these events is leaning towards crazy. A while back I was determined to make some myself, and while getting a bowl of ice cream, it came to me... chocolate shell!
It hardens on ice cream, why not a chilled banana? I gave it a go, and here is how I did it.
Step 1: Ingredients
You will need:
Ripe bananas (as straight as you can find)
Kebab skewers
Magic Chocolate Shell (store bought or homemade)
Aluminum foil/ wax paper/ parchment paper
A bowl (preferably one with corners or a pour spout)
A spoon
Step 2: Prep
First you will need to peel your bananas, I'm only going to do one here for simplicity's sake.
Then you'll want to insert your skewer about two thirds of the way into your banana (my straight one broke in half inside the peel, so I had to get a replacement, not very straight). I use another skewer to judge approximately where the tip is.
Then place your banana on your tray and covering of choice.
Step 3: Time to Chill
Now, waiting...
Put your bananas in the freezer for about thirty minutes or until it's nearly frozen. You don't want it frozen solid, just cold enough that it will harden the chocolate later on.
When it's almost time to take them out, pour your chocolate shell into your bowl, and have a spoon ready. Don't forget to shake/mix your chocolate, because whether it's homemade or store bought, it contains oil, and things that contain oil separate over time if it's left untouched.
Step 4: Coating
Now, remove fruit from freezer, and one at a time place the banana into the bowl, and use the spoon to coat.
Once the first coat hardens, feel free to add a second.
Then if you're doing more than one, place banana onto your papered or foiled surface and grab the next.
After that, more waiting. Put the bananas back into the freezer for about another ten minutes.
Step 5: Finished
Congratulations! Your frozen treats are now finished!
Remove from freezer as needed and enjoy.
Watch out for the tips.
NOTE: If small children will be enjoying these I suggest cutting bananas in half (skewers too) and cutting off sharp tips with scissors.
Thank you for sitting through my first instructable!
FINAL NOTE: Returning any extra chocolate to bottle or storage container is up to you, the reason I use square bowls is because it's easier to pour.
Finalist in the
Stuff on a Stick Contest
