Remove these ads by
Signing UpStep 1: Ingredients
Lemon Juice - 1-2 table spoons
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
First, note that most fruit leather is 90% apples with 10% blueberries, plums, strawberries or other – or 100% apples.
Cut the apples into quarters and remove the core. Leave the skin on. Cut smaller and fill a big microwave-proof bowl. Add a small amount of other fruit if you like. Microwave until the apple is cooked (doing it in the microwave means you don’t have to add extra liquid to prevent it burning).
Now transfer the fruit to your food processor, add a good dollop of honey and process until everything is pureed.
In a small room in your house, set up a de-humidifier and a sheet of plywood or similar covered with a piece of 6mil polythene (the fruit leather doesn’t stick to poly). Spread the fruit puree onto the plastic at about quarter of an inch thick, switch on the de-humidifier and close the door. In about 24 hours or maybe less, the leather is dry enough to be peeled off and turned over. Another 24 hours and it will probably be ‘done’. Roll it up and bag it as it is hygroscopic.
I actually made a gadget to spread an even ¼ inch layer of the puree 6 inches wide, rather like a hopper. This is just a simple wooden box about 6 inches wide and 2 inches across and 2 or 3 inches deep, open top and bottom. But one of the long sides is ¼ inch less deep so that when placed on the plastic there is a ¼ inch slot at the bottom. I fill the hopper and as I drag it across the plastic it deposits an exact 6 inch wide x ¼ inch thick ribbon of puree.
Use the units you want, ant let others do the same. But this is all about communication, so specifying the units you are using is part of a good communication.
I've always wanted to try drying fruits for hiking and mountaineering, will try it out one of these days...
ehm.. for "tonygoffe"... i think that's a great question by Korlee, since instructible members aren't only people residing in the US, and certainly not everyone are using the Imperial Measure.
Cheers..
many more I expect, so we generation that are stuck in the past have to try converting everything from metric into imperial which is a nightmare,
so just leave the pint, quart, 3/16" 2" etc alone and get on with your life,
in peace
michael
SUGGESTION : ALL Instructables should be posted in BOTH systems..so that the rest of the world may benefit.............not that difficult1!
Also do you have to add the lemon juice? Or is it just for preserving it?
Lovely instructable! Gotta try at next summer, there's no strawberries in 0,5m of snow ;)
So it's about 60C :)
sunshiine
Thanks for the reminder, now I just have to wait for a summer so I can harvest some strawberries, mind you I don't think here in the UK we've seen a summer for years. :-)
