Fruit Picker out of stuff you have laying around
 by adreyer1
Featured
Are you tormented by seeing oh so tasty fruit that's out of reach?  Miffed at seeing fruit go to waste because it's just rotting on the branches?  Having a crisis because you'd just LOVE to put that fruit to use but just can't get to it?  Fear not!  You can make a simple and quick fruit picker out of things you may have laying around, or that you can stea-ah, borrow
Step 1: Implements of making
The thing you'll probably have laying around is a two liter bottle.  If you're a crafty crafter, you'll likely have some long stick thing laying around, some screws, and tools that are good for cutting into other things, like boxcutters and saws. Screwdrivers are pretty essential, but then again, what are you doing with screws if you have no screwdriver?  Try making some sense here.
Step 2: Messing with the bottle
For illustrative purposes, I drew a line on the bottle showing you where I plan to cut.  If you have a fondness for markers, feel free to do the same, but it's not really necessary.  Just make sure that the notch at the neck of the bottle is wide enough for thin branches, and the body of the bottle has a hole large enough to accept whatever fruit you're going after.  You may have some issues going after watermelons with this thing, but then again you could just walk up to it and pick it up.  Again with the silly questions.
Step 3: Screw this.
I admit that I hadn't thought this one completely through.  I knew I didn't want the hole for the fruit to dip too low so that the bottle would have as much stability as possible, but I also wanted to have the screws on the lower half of the bottle since the plastic is thicker there.  That means part of the bottle blocking access to the screws, unless you have a very tiny screwdriver...
Step 4: Completion!
You should now have a fabulous fruit picker!  Feel free to wave it around proudly while proclaiming how your civilization has now progressed to making simple tools.
Step 5: Execution!
This worked beyond my expectations.  The neck of the bottle is stiff enough that I could tug down on the fruit and the stems would snap, the shape of the bottle made it pretty easy to slip between branches, and the pole makes for easy access to those fruit that dare defy you by growing out of arm's reach.  In fact, I was so pleased with the ones I managed to get that I went back and screwed an extension to my pole since I had another piece of wood laying around.  Beware, fruit picking can be addicting, I was tempted to add a third extension because trees have a bad habit of growing tall, but I might have to rein myself in.
   If had free access to custom materials, I'd probably make a sturdier "basket" for grabbing the fruit, there were a few times where it collapsed and popped back out again when I was trying to get at some difficult pears.  An extendable pole would be quite handy, or even a hollow pole that would let the fruit slide down to you, but that could be more unwieldy than the basket method, especially if a fruit got stuck.
   In any case, I hope you enjoyed my first instructable!
crimartin1 says: Sep 16, 2012. 9:21 PM
genial!!!, ahora sé cómo bajar esas mandarinas que se pudrían en el árbol.!!
AussieAnglerGal says: Sep 13, 2012. 5:58 PM
hmmm..given me great ideas to get those ridiculously high-up mulberries..thanks!
adreyer1 (author) in reply to AussieAnglerGalSep 13, 2012. 9:36 PM
I was discussing the problems with picking mulberries since they're much smaller and they'd slip right through the mouth of the bottle. A possible solution would be to either heat and pinch the mouth to make a smaller opening, or what might work better is to keep a bottle cap on top and drill a hole and notch through it that's just a bit bigger than the berries. If I remember right, the properly ripe berries tend to practically fall off anyway, so they won't need as much of a tug to get them down.
AussieAnglerGal in reply to adreyer1Sep 14, 2012. 12:23 AM
ok great thank you!
Treasure Tabby says: Sep 13, 2012. 8:06 PM
I sort of have that problem with my peach tree until our local annoying squirrel comes along and helps him self to those large yummy just out of reach cause their on the tippy top of the tree, peaches. That little bleep can barely carry those large beautiful ones in his mouth and many times I find them smashed on the floor. :( One time he mocked us by eating one of those beauties on his favorite branch right in front of us. >:(
But yeah I would use this if I could.
Now if some one could come up with a genius solution to keeping squirrels out of our peach tree, that would be nice.
adreyer1 (author) in reply to Treasure TabbySep 13, 2012. 9:34 PM
Next instructable: Solution to pesky squirrels: Chimera DNA to give cats wings. Hrm, that's not nightmare material...In any case, thanks for the comment! I would LOVE to try this out on a peach tree, mostly because I love peaches. :)
Kiteman says: Sep 8, 2012. 2:36 AM
Oh, excellent project, and I always love to see ideas for improvement.
adreyer1 (author) in reply to KitemanSep 8, 2012. 11:29 AM
Thanks! Maybe it's the art background that does it, I was taught to critique things, especially my own stuff.
agzhanesh says: Sep 8, 2012. 8:45 AM
nice
agzhanesh in reply to agzhaneshSep 8, 2012. 8:48 AM
very nice
skgreenman says: Sep 8, 2012. 8:28 AM
Makes me wish we had a pear tree. Great use of common items. Thanks for the tip.
MuhammadHaris says: Sep 8, 2012. 7:11 AM
Sort of a cool Instructable!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
