Full Size Platform Bed
5,912
157
11
Published
Introduction: Full Size Platform Bed
So after watching hours of videos and reading tutorials I decided to build a full size bed for my daughter. I must say it was quiet a learning process as I was doing it for the first time and wasn't sure on the type of tools needed for this project.
Here is what I bought from HomeDepot :
  1. Deck Screws - 1 Box 2.5'' and 1 Box 3'' (~$20)
  2. Flat Head Screw - Small box 1.5'' (~$4)
  3. 8 - 1 x 3 Strip (~$15)
  4. 5 - 2 x 4 Strip (~$16)
  5. Wood Glue - 1 Tube ($6)
  6. Drill/Drive Kit (~$13)
  7. Drill (~$30)
  8. Measuring Tape (~$14)
  9. Spray paint (~$5)
Full size bed dimensions are 75'' x 54'' and normally wood strips come in 96'' in length. So you need to cut them according to the dimenssion better would be if you get it cut from the store itself.
  1. Three - 2x4 - (96'' - 75'') = 21'' (Use for legs)
  2. Two - 2x4 - (96'' - 54'') = 42'' (Use for legs)
  3. Eight - 1x3 - (96'' - 54'') = 42'' (Use for headboard)
Step 1: Legs
Use remaining 2x4 wood strips for legs. You would need 8 legs, build them by joining 10'' and 6.5'' 2x4 wood strips as shown in the picture. Glue the pieces and screw them with two 2.5'' screws.
Step 2: Attaching Legs
Glue and screw legs onto 75'' 2x4s. For sides use 3 legs and for middle support use 2 legs.
Step 3: Frame
Glue and screw 54'' and 75'' 2x4s wood strips using 3'' deck screws. Do it from all the sides and then screw 1x3 strips in the gap of 7.5''.
Step 4: Headboard & Final Assembly
Use remaining 1x3 strips for building headboard. Take five 40'' 1x3 strips and join them with two 53'' strips. Cut 20'' pieces from the remaining 1x3 and screw them in the gap (as shown the picture).
Here you go full size bed in about 6 hours costing around $80 :)
2 People Made This Project!
  • Make it Move Contest
  • Woodworking Contest
    Woodworking Contest
  • Casting Contest
    Casting Contest
11 Comments
Thanks, good to see that you've made pretty good progress. Yes, cutting is very time consuming unless you have professional tools. I got the legs cut at Home Depot itself.
Was measuring an looking at this great example but I am ignorant and the cut list to me seems simple but very confusing since you identify all kinds of sizes not on the list, but the result of the math without further explanation:-( I will try to evaluate quickly thanks!
Nice work. I built a platform bed several years ago and have not had back problems since, they are great.
I always like furniture making instructables. Great effort! There is a nice cheat to make this much easier: use Ikea slats
http://m.ikea.com/ca/en/catalog/functional/10376/24827/#/ca/en/catalog/products/art/60160217/
if this is without a box spring, then you may want to remove the middle support
I added middle support to make it sturdy but yes it can be removed.
This frame looks great!
Just watch out though, bed frames are the gateway drug to making. You'll be taking on bigger and badder stuff in no time! :)
I've made several beds like this, to add friction that will help keep the mattress from sliding about, wrap and staple shelf liner on several of the slats, the rubber-ish stuff is cheap, about $1.00 a roll at discount stores.
