This is a prop I built for a Star Wars party. I didn't want to spend a lot, but I did want it to look cool.
I know that there are some incredibly talented folks who put years of effort into making awesome R2D2 and other droids, but I wanted something inexpensive and I only had a few months until the party. So rather than use sheet metal and fiberglass, I used mostly cardboard and wallboard joint compound. I also use a lot of stuff that I had in my junk-box.
Yep - that was once a used refrigerator box!
Remove these ads by
Signing UpStep 1R2D2 frame and covering
Google image search is great!
I acquired a few refrigerator boxes at a local retailer and got to work.
I created a frame for the body, then wrapped the cardboard around the frame.
This is a bit tricky. You'll need to soften - but not drench - the cardboard by spraying it with water and letting the moisture soak through the layers. When it's sufficiently soft, you're ready to wrap it around the frame. Apply hot glue to the edges of the frame and attach the softened cardboard sheet to it. I recommend that you get some assistance with this step.
It has a few inconsistencies, but we'll compensate for that later.
This IS the droid we've been looking for.
Thank you for you attention, and sorry if I am being a drag.
does putting people down make you feel better ?
maybe you didn’t realise you were putting that person down but you most certainly were
Then coat the whole thing with paper mache or the wall joint stuff and paint.
try; http://astromech.net/
The 3rd leg astromechs have needs to retract in order to fit inside the slot in the back of a starfighter.
After your done, you use paper mache to smooth out the surface and then you paint the design.
A couple of people have mentioned bowls, which I don't think are going to be the right shape, but perhaps hemisphere baking pans would work? They come in a variety of sizes, and are perfectly round hemispheres. It's what bakers use to make planets, baseballs, etc.
